I read this can somebody tell us what it means it might be helpfull?
Username: Borinick
Post Number: 485
Rep Points: 1146
Default Ukr_-PUFF-ConversionFlashFix
This was put together some time ago by Ukronic, it is a flash "cleaning" file
If you are having problems with the latest bin run this first then load the latest bin.
As always use at own risk. post results in the discussion section.
P.S. this is made by Ukronics, anything made by Ukronics can be trusted, he was one of the originals.
WARNING: Use all files at your own risk. Attachment Issues? Click Here
Username: Nydas
Post Number: 13919
PUFF_204 flash problem '" Full kit for fixing the problem.
Use UKR's Flash Fix. Use at your own risk.
Alternative Flash Fix link
Download and unzip into separate directory.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
This is a last resort method
Follow the instructions in the word file
"UKR Flash Fix for conversion boxes.doc"
Username: Rekman
Mntl-Quebec-...
Post Number: 510
Hi Nalin Nyda.
I understand you have many to reply here... Can you Please reply to mine.
Since Wednesday my Receiver showing No Signal (I mean quality is 0)
I want to know ,Has the FTA Changed Satellite Dish position
OR Is it the Wind which has turn my Dish ,,,
(because last day there was strong wind} )
