Correct way loading PUFF 204 here
Username: Jkmago
Post Number: 262
Hi Guys,
Follow what Nalin says
Download additional file UKR Flashfix
To start off
Use Updater 1.4
Using Ukr_-PUFF-ConversionFlashFix.bin (1mb)
Off/On your box...on first light....hit write and be patient.
IF successful write, box should Display 'rolling PUFF'.....
at this point using same loader and same Off/On method..".
Load in Fwank7_Jvvh-Team-PUFF_V204.bin (448k)
when all done.
Antenna set up rescan and Ebjoy
Great!
Username: Jwl1
Post Number: 343
On fta.talk the bin comes in a folder with a different style of loader with what appears to be different directions.
Therefore, could you clarify that you are referring to the Blacklist 1.4 loader?
Nalin's way sounds a lot easier.
Not to cause any confusion here, but this is the instructions on fta talk which sounds as if it more work than necessary.
It has not been tested by me but has been tested
by others and reportedly is tested and working fine!
Step #1
Open the GTrom loader and Pick Boot file
Choose the 101 boot file and hit Download
Wait to see ON
Step #2
Open Fwank7 Jvvh Team-PUFF Loader
Change the Model to Lifetime Ultra
Choose the latest V204 file
Turn on the box
As soon as you see the first "P" hit Download
Wait until the box completely reboots to On
You should be good to go
Username: Jkmago
Post Number: 263
Joe,
Download from nalin website two bins one UKR Flash fix bin and Fwank 204 that all you need.
Please use BL 1.4 updater for both.
First run Flasahfix 1 mb file and wait for PUFF to display and then switch off then open loader select file and as soon as P appears hit write for Fwank 204 and wait for on to appear on receiver and then switch of and connect with TV and do antenna setting and Blind scan.
All good.
Cheeers!
Username: Jkmago
Post Number: 274
Just need two bins
UKR Flash fix and Fwank 204 PUFF and download from Nalin website
Switch off the receiver
open BL updater
Select UKR Flashfix and switch on receiver and hit write as soon as switch on and wait for Rolling PUFF to appear and when it stops at F then Switch off receiver
Open BL updater
select Bin Fwank 204
switch on receiver and as soon as you see P on receiver hit write
and when wait for On to appear on receiver
again switch off
connect with TV
Do Antenna setting
Do blind scann
all good
Enjoy TV
Username: Shadow45
Mty, Nuevo Leon Mexico
Post Number: 302
For some reason the method described above didnt work for me, i have a lavasat 3200 converted to pff,when i loaded the UKR the way you said , it stays on rolling puff....what to do now..?
edit: disregard this post, seems i was able to do it eventhough it got stuckon "rolling puff", i tunred it off and loaded the 204 and i was able to get all the shiznit again...thanks to all for the help.
Username: Nydas
Post Number: 13925
201, 202 203 and 204 are full EMU BINs.
299, 300, 301 are NOT full EMU.
Channel master or saved channel list may only be used (with luck) directly from 299 list to 300 or 301 list, although I did have problems using a 299 list on to 301.
Also you may try using a 203V2 saved channel list on a 204 load. It may or may not give problems.
The best thing to do, and I have advised this often enough is for PUFF converted boxes:
1. Note down Antenna settings.
2. Delete all channels.
3. Do a system reset.
4. Do hardware reset (turn off and on from back switch)
5. Load PUFF_204 BIN.
6. Do hardware reset again.
7. Do User setup including time. Remember that even a wrong time might send the EPG searching.
8. Do ONE antenna setup. Do not use a user defined satellite.
9. Do hardware reset again.
10. Do one blind scan.
11. You WILL see TV at this stage.
12. Do hardware reset again.
13. Do other antenna setups.
14. Do other Blind Scan.
15. Do Favourites and Parental control.
16. Do hardware reset again.
17. SAVE THIS under Channel master for later use.
18. Watch TV using FAV and EPG instead of haphazardly scrolling though channels.
There may be too many hardware resets in the above, but remember they only take a minute at a time.
When the dust has settled and the full EMU BINs are more robust, you won't have to go through such an elaborate process.
Username: Patches123
Post Number: 36
Followed procedure for two machines; converted FLU works great, the converted Pansat 2500A now has zero quality on 110 & 119; the same thing happened the first time I loaded these new bins and I had to take it in to someone to have it fixed...any ideas on what he did to get it going last time?
Username: Ply_mouth
C&P 6070
Step #1
Wait to see ON
Step #2
Turn on the box
Username: Adrenalyzer
Post Number: 98
can i delete all music chans, and keep the tv chans, and D.L the 204 bin with success???
Username: Jkmago
Post Number: 277
No, You cannot.
you need to delet all channels and do system reset
Load UKR Flashfix and then load Fwank PUFF 204
Cheers!
Username: Jwl1
Post Number: 344
Puff V204 Freezing on "F" Fix
Step #1
Wait to see ON
Step #2
Turn on the box
Attached Files Pansat 2500 Fix 1-17-09.zip (900.7 KB, 735 views) This can be found at ftatalk (.com)
Tested and works. However, it's recommended from most to first do a factory default (which deletes all the channels as well) before loading the new boot and bin.
Of course, you will need to set everything up again. Therefore, you may want to write your settings down before you start.
Username: Mkvl1490
Post Number: 174
I'm confused. We dont have to do Nalin way and it will be fine
