2700A Help
Username: Sparky41701
Chavies, Ky Usa
Post Number: 124
Ive been gone awhile is there a puff bin for the 2700A to get all the channels i can get some but not all if there is a bin can some give me the instructions thanks in advance
Username: Nydas
Post Number: 13692
For genuine 2700A use the
X-87BL_081215_B75_V203_api_femu.bin from
http://www.future-fta.info
The PUFF BINs are meant for Pansat 2500 or Fortec Ultra converted to 2700 workalike.
They should NOT be used on genuine Pansat 2700A/E
Chavies, Ky Usa
Post Number: 125
Thanks Nalin Is there anyway to get all the channels back on the 2700A what i do have i have 4 of them
Username: Nydas
Post Number: 13694
If you have genuine 2700A, you must
1. Delete all channels. Note down Antennas settigs.
2. Reset
3. first install the latest Factory BIN 124,
4. Reset
5. Install Full EMU 203 BIN.
6. DO NOT use saved channel master List.
7. do user setup
8. Do Antenna setup and scan one sat.
9. Let the autoroll work and show you TV.
10. do other scans.
11. Save THIS under Channel master for future use.
