Signal no quality on 2700a - help
Username: Hoptan
Post Number: 9
ever since the new emu files were released - i have this problem with good signal and poor quality - picture does not seemed locked in on any channel
Username: Nydas
Post Number: 13734
The new EMU BINs can be troublesome at times.
1. Note down your Antena settings.
2. Delete all channels.
3. Reset. Switch off at the back and ON after 40 seconds.
4. Install the latest 124 factory BIN.
[link removed]
Use 27.02 loader
5. Reset. Switch off at the back and ON after 40 seconds.
6. Install the latest 203 full EMU BIN.
http://www.future-fta.info
7. DO NOT USE any channel master or other channels list.
8. Reset. Switch off at the back and ON after 40 seconds.
9. Do user setup.
10. Do one sat antenna setup.
11. Scan. Turn on autoTP if autoroll does not work. Wait for 20-30 minutes for picture.
12. Do other sats antenna setup and scans.
13. Do Paretal controls, and channels edit and set up favourites.
14. SAVE THIS channels list under Channel master.
http://www.sharpc.com
FOLLOW THE INSTRUCTIONS PRECISELY FOR FAILURE PROOF LOAD
HAPPY VIEWING
