Dont swith of the receiver
Username: Kaanwal
Windsor, Ont Canada
Post Number: 22
After downloading puff 201, file dont switch off the receiver it will work for sure. down load it in the unit where u dont have to switch it off.
Username: Jkmago
Post Number: 236
The other way of loading if one can not directly load.
One can switch off but after loading do not wait for on and chaannel to appear rather switch off as soon as P appears.
Load in the following way to avoid endless Puff
Load V201_Full_EMU once you see complete and Let the box reboot, but power off as soon as when you see the first 'P'.. and do not wait for on and channel number to appear.
Hook up to TV and power on...
This way one can stop only endless Puff and shows very good signal strength but no picture.
Some one may look into and inform the result.
Thanks
Username: Justforhahas
Post Number: 1499
c/p fwank7
V201_Full_EMU works good but has same issues as everyone else and that's when you reboot receiver you get rolling PUFF...
If your receiver is not by the computer, soon as download is complete and you see the first" P " turn the receiver OFF...
Then hook it up and power it on but don't turn it OFF again or it will go to rolling PUFF.
end c/p
So to recap...
Load V201_Full_EMU
Let the box reboot, but power off when you see the first 'P'..
All should be ok!
Username: Nydas
Post Number: 13486
If you are going to use the new PUFF_201 BINs, you will have to accept some limitations. NOTE that this applies to PUFF BINs on 2500/FLU conversions
Rolling PUFF workaround...
c/p fwank7
end c/p
So to recap...
Load V201_Full_EMU
All should be ok!
Then DO NOT SWITCH IT OFF!!
