Puff
Username: Dj_asya
Montreal, Qubec Canada
Post Number: 58
hi is there any file working because i have installed the full emu 201 and is not working u have guys have any link please send or solution thank you and please pardon because i poen a new thread thank specialy nalin could u help me plz tnx bye
Username: Justforhahas
Post Number: 1506
c/p fwank7
V201_Full_EMU works good but has same issues as everyone else and that's when you reboot receiver you get rolling PUFF...
If your receiver is not by the computer, soon as download is complete and you see the first" P " turn the receiver OFF...
Then hook it up and power it on but don't turn it OFF again or it will go to rolling PUFF.
end c/p
So to recap...
Load V201_Full_EMU
Let the box reboot, but power off when you see the first 'P'..
Hook up to TV and power on...do NOT shut OFF
All should be ok!
Username: Dj_asya
Post Number: 59
justforhaha's
still having problem no picture the signal goes up and down could help me plz
Post Number: 1510
Check your cables and connections again, if losing picture in/out...also switch connection, or some cable or the switch may be going bad..FIRST try a REBOOT, using rear switch off/on..good luck
Signal Strength means nothing except that LNB is connected good to receiver and they are communicating, it can be good even if dish is aimed at the ground..various transponders and channels will change that too ...Signal Quality is very important and different than the strength..
Username: Nydas
Post Number: 13490
If you can't get out of the PUFFing, try installing an older BIN and then the latest Fwank7 PUFF_201 BIN.
If you are going to use the new PUFF_201 BINs, you will have to accept some limitations. NOTE that this applies to PUFF BINs on 2500/FLU conversions
Rolling PUFF workaround...
c/p fwank7
end c/p
So to recap...
Load V201_Full_EMU
All should be ok!
Then DO NOT SWITCH IT OFF!!
