Pansat 2700A Freezing After new BIn Upload
Username: Det
Post Number: 98
hi
when i entered the new bin (full EMU) my pansat started freezing. so i kept on turning it on and off from the back. can anyone tell whats wrong?
Username: Alftabin
Post Number: 69
My pansat doesn't work at all with the new bin.
Username: Dirk_diggler
Post Number: 25
try reloading the bin again
Username: Ciscomx
Post Number: 38
mine is periodically resetting itself.
Username: Nydas
Post Number: 13514
Do factory reset, install factory BIN 124 using loader 27.02 and then install the full emu V201 BIN.
You will have to do setup and rescan.
Avoid using Channel master for loading channel list.
Username: Alftabin
Post Number: 70
Where to get factory BIN 124?
Username: Albino_midget
Post Number: 718
www.pansatusa.com/download/2700A(b-75).zip
Username: Mohamad_obama
Terhan, Iran Iran
Post Number: 249
Ask Rose bud, the pancrap queen.
Username: Det
Post Number: 99
i did what u said nalin, a little bit. i factory defaulted, but i scanned before i put the bins in. will that affect anything, also when can i start using channel master? someone told me after your done loading a bin u have to write to stb.
Username: Nydas
Post Number: 13561
The new 201 BIN is not fully compatible with memory locations of scanned channels.
You may end up having to scan and rescan.
1. Factory 124
2. Latest BIN.
3. User setup
4. Antenna setup.
5. Scan one sat and REMOVE unwanted channels.
6. Do same with another Sat.
7. Try and pretend everything is back to normal!
Username: Plymouth
Post Number: 6291
Nalin is it possible to deleted provider in keys menu as for Viewsat?
Post Number: 723
what is the purpose of deleting provider on a viewsat.
why not just load the opkey.
Username: Plymouth
Post Number: 6294
Albino Midget
Few receiver functions are insert in Provider Keys, deleting providers erase bad data in receiver and many times that recover many problem with no signal, autoroll and Tp lost.
Username: Det
Post Number: 100
il try. i found a
Cool sat FTA Satellite Receiver 6000 Premium with Universal Remote Control Almost New. is it a good reciever, should i buy it? is it the one with the usb port?
