B-75 to PUFF help...
Username: Hockeycraze12000
Hi!
I have a fresh converted Fortec Lifetime Ultra and I have converted it to Pansat b-75. I haven't loaded any bins on it yet. (except the default ones for conversion).
Do I need to convert it to Puff?
Are there still files for b-75?
And if there is, what loader do I use?
Thanks!
Username: Aryan
Mississauga, Ontario Canada
Post Number: 82
up to U buddy, u will get bins for both B75 and puff form all thanx to Nalin.
puff has added advantage that u do not have to rescan channels every time bin changes.
FYI as of now all are waiting for new bin so keep cool and wait for file.
Username: Mrgreg
Ont. Canada
Post Number: 186
I had both conversions and am on PUFF now but on b75 I never had to rescan after putting in new file.
Thanks for that, answers a lot of questions!
What loader do I use, by the way?
Username: Mrgreg
Ont. Canada
Post Number: 188
Blacklist 1.4
Post Number: 7
I use GtROM 27.02, is that okay?
Username: Elvirm
Post Number: 73
I still have b-75 and have files (usually from Nalin), and working well.
Username: Mrgreg
Ont. Canada
Post Number: 190
Just use the ones you are conv. with.
Username: Nydas
Post Number: 13426
Loader 27.02 is for genuine Pansat 2700.
For converted receivers use BL updater 1.4 for all activity except for revert to 2500.
Username: Nydas
Post Number: 13427
I do not fid the coversion b-75 and PUFF BINs much different in behaviour. To me the only difference is that the support for PUFF is much stronger and quicker, and I can use the tronic direct conversion (1.5-GUI) for quick PUFF conversion.
Post Number: 8
Ok, now I'm stuck on F for some reason.
Anybody know how to fix?
Post Number: 9
....This happened because I just converted to PUFF
Username: Lucia
Calgary, AB
Post Number: 684
khalid sometimes it takes like 3-5 minutes for the F to disappear
