OSCAR DE LA HOYA vs PACQUIAO what channel
Username: Snagovac
Post Number: 68
anybody have a idea what channel it is on
Username: Plymouth
Post Number: 6210
Damir
It seems to be on 9467 and 539
Username: Snagovac
Post Number: 69
we only have dish last week i did not be able to find ppv to watch ufc where could i find channel 539 please answer me thank you
Username: Plymouth
Post Number: 6213
Damir
#539 Echo 10,11 110W Tp 6 L 20000 5/6
Do a auto scan on 110 before the show and you will get this channels
Username: Fumb_duck
Damir, plymouth failed to mention you will need HD receiver and 8psk module for channels 9467 and 539. Upload
Username: Bouttep
Post Number: 98
usualy they have those fights on 455 / 472
Username: White_girl
Post Number: 43
C/P
Username: Snagovac
Post Number: 70
hi guys and how can i check if i have 110w or 119w right now i am watching preview show de la hoya vs pacquiao on channel tv456 and everything is to 9 preview show after nine the channel turns off next channel tv467 pre order it says to go on channel 455/472 but i do not have those channels PEOPLES I DO NOT KNOW WHAT TO DO I HAVE TO WATCH THIS FIGHT thank you please help
Username: Snagovac
Post Number: 71
i forgot to tell you i do not have echostar 11 i have echo 7,8,3,4 thanks please help me thank you
Username: Albino_midget
Post Number: 714
Do a TP scan
CH# 455 E-7 TP 12355
CH# 472 E-3 TP 12661
Username: Plymouth
Post Number: 6227
Damir
Echo 8 is 10,11 now on position 110.0W
Do a autoscan on 110w before the show.
Username: The_coders
Post Number: 1556
it's ECM time kiddies - no fight tonite
Username: Plymouth
Post Number: 6228
Username: Anonymouse
Post Number: 63
It would've been on 455, 456, and 472
Username: Feroz
New york, New york U s a
Post Number: 52
yep ecm time they could not find a better time !!!!!!!!!1
Username: Snagovac
Post Number: 72
ok hi albino i scanned 12355 and i get channel tv9464 and on that channel it says you order for boxing on channel 9467/539 but i do not if it is going to turn on boxing when the boxing will start what do you think i should do thank you please help
Post Number: 715
damir.. channel 9464 is on echo 8 TP 12355,
you need to scan echo 7 TP 12355
Username: Snagovac
Post Number: 73
albino i scan echo 7 tp 12355 and i get 31 channels but there is not channel 455 and i got channel tv468 and it says you order for boxing on channels 946/539 i don't know if i did it right and i do not know if this in 110w or 119w thank you please help
Post Number: 716
Channel 468 is at110w, you want 119w.
Do you have dish 500 , maybe you have diseqc ports wrong in antenna settings(ports for echo7 and 8 would need to be switched)
Maybe you have dish with single lnb pointed to 110w only?
Username: Snagovac
Post Number: 75
i have antenna with triple lnb but i only hooked up one lnb what do you think should i hook up the rest two that are not hooked up
Username: Ciscomx
Post Number: 36
Internet
http://www.justin.tv/hufhjd
Post Number: 717
damir , I don't know what dish you have.
if its a dn dish add the lnb's.
or re-aim the dish to 119w
www.dishpointer.com
Username: Jayson
Post Number: 269
wtf...DN is down anyways......
Username: Justforhahas
Post Number: 1482
DN has an ECM in progress since 5PM EST...All receivers using DN channels are down, except Nfusion on IKS...No older files reported to work....NEW FILES ARE NEEDED, NOT KEYS! .....Be patient and wait for new files from www.ftabins.net ..files usually takes a few hours so don't expect anything until at least 10 PM EST or later as a guesstimate...GC is still up , except for their Nagra 3 channels...Bev is dead too except for some N3 channels on Nfusion IKS...The fight is stream live on www.justin.tv/hufhjd
