How to Install New Receiver?
Username: Laguna
Post Number: 18
I ordered a new receiver(conaxat) and need basic install help. Do I just replace the old dish network receiver with the new receiver and replace the splitter switch and I should be good to go? Thanks for your help.
Username: Lomna
Post Number: 416
You bought ur rec very very late. They are going to be dead within days my friend !
Username: Mohamad_obama
Terhan, Iran Iran
Post Number: 238
Go to a site where you can get help and read, read read.
You won't get step by step here.
Username: Plymouth
Post Number: 6214
Vicente
We can help you here don't listen this Mohamad Obama, he is a troublemaker.
Yes you can replaced the existant Dn receiver for the CNX
Is it the first receiver you buy?
What you want know and which satellites you want get?
Username: Justforhahas
Post Number: 1472
For Conaxsat info, use their best unofficial home site...they have all the CNX experts, guides, videos, manuals, files, and chat..
[link removed]
Username: Nydas
Post Number: 13409
Mohamad Obama and justforhaha's are trouble makers.
Get help from Plymouth.
Username: Runnerguy
Pluto
Post Number: 1687
Username: Plymouth
Post Number: 6220
Zulu
Are you g.a.y?
Cause i'm not, i prefer girl, you lose your time with me, try with jjgee.
Username: The_coders
Post Number: 1542
Username: Runnerguy
Pluto
Post Number: 1688
Username: Laguna
Post Number: 19
Getting all the dish channels and Indian from DN pay service.
So, I think I will need 148, 110, and 121 satellites. My basic question is should I be able to just replace the receivers or is there some other tweaking required? Thx.
Username: Plymouth
Post Number: 6223
Vincente
Where are you located? (state)
If you have a Dp switch and a Dn dish, you can get channels.
Which LNB is on your dish?
Post Number: 1479
You must configure/input your FTA antenna/dish receiver settings to exactly which hardware (switches in use, which switch ports are in use, LNB types, sats/lnb's aimed at, etc) ...the same EXACT way Dishnet has your roof dish configured and set up... You will need to climb the roof and take a look, at a minimum.
This is NOT Plug N Play..
Username: Jay_w_grayson
Prague, Oklahoma USA
Post Number: 138
Post Number: 1555
LK is , she luvs little boys doncha alkie
Username: Gregraf
Post Number: 1707
Don't you think Nalin looks a little funny?
