Username: Link119805 Post Number: 37 Registered: Sep-08
Tuesday, November 25, 2008 - 17:27 GMT does any one know how to setup echo 5 (129) on a pans3500sd plus? There is no echo 5 on the sat list? di they rename it or is it something else? any help would be really appreciated. thanks
Username: Tooter Post Number: 69 Registered: Oct-08
Tuesday, November 25, 2008 - 18:10 GMT you could set it up as echo 4 ... there are only 5 TP's that are not HD. 12282 V 12443 H 12457 V 12516 V 12676 H double check with lyngsat Just make sure LNB freq 11250 and proper switch port.
Username: Jay_w_grayson Prague,
Oklahoma
Post Number: 121 Registered: Jul-08
Tuesday, November 25, 2008 - 19:15 GMT Chumley is right about the TPs. There is about 90 Local channel on those five TPs go check this link yourself. http://www.lyng/sat.com/packages/dish129.html If you still want to use EchoStar 5 at 129.0°W pull up EditTP/Satellite stroll to "NEW" and add it to your receiver. btw....do not use EchoStar 4 it's already in use @77.oW
Username: Kirankumar NO Bashing
Post Number: 3060 Registered: Oct-07
Tuesday, November 25, 2008 - 19:18 GMT why would you want to set up on 129 ? have you thought of 119 ?
