Silver Member Username: VittuPost Number: 268 Registered: Oct-07 | I need to have someone re-align my dish antenna pointing towards 119. I do not get signal any more. Asking it for a friend otherwise I could have it done. Please PM me. Thanks |
Gold Member Username: PlymouthCanada Post Number: 5825 Registered: Jan-08 | vittu read this thread: https://www.ecoustics.com/electronics/forum/home-video/529275.html |
Silver Member Username: VittuPost Number: 269 Registered: Oct-07 | Merci Plymouth, mais je ne suis pas en Calgary. C'est pour une des mes amie que je besion d'aide. Elle n'auras capable a faire elle-meme. |
Gold Member Username: PlymouthCanada Post Number: 5826 Registered: Jan-08 | Vittu Right she(he) can use a FTA reseller in Calgary. |
Gold Member Username: Saqeeb9000Post Number: 4245 Registered: Oct-07 | vittu pm me and if u still need installer , i can tell you, |
New member Username: PunmcPost Number: 1 Registered: Nov-08 | anyway to swtich off 118.5 (international stuff) and pick up 110 |
Gold Member Username: Saqeeb9000Post Number: 4267 Registered: Oct-07 | i am sure you can,but u have to move the dish slightly, i won't recommend it, why don't u buy an extra lnb (cost $15-20) and a bracket and u will have 3 dishes togeather double check with nalin and plymouth for this.. |
New member Username: PunmcPost Number: 2 Registered: Nov-08 | Would i not have to buy a new arm or unit that could hold 3 lnbs? I just thought that if i changed the freq. that I could cheat and get 110 instead |
New member Username: PunmcPost Number: 3 Registered: Nov-08 | i thought maybe i could change the freq. and be able to pick up 110. |
Gold Member Username: PlymouthCanada Post Number: 5862 Registered: Jan-08 | jt Which dish you have? |
New member Username: PunmcPost Number: 4 Registered: Nov-08 | If you mean brand I am sorry but i think its gener. size its a 30inc dish i have a vs ultra |
Gold Member Username: Saqeeb9000Post Number: 4268 Registered: Oct-07 | jt the easiest way to do this is to buy a bracket cost $ 5 and lnb then u have to adjust the dish then u will get 110 dish, b.c i am sure u don't wanna keep 118.7 either, there is no other way around it, if u wanna get 110 , u have to physically move the dish,rec setting won't help |
Gold Member Username: Way2smartWww.Desifta.com Post Number: 1669 Registered: Oct-06 | go to fx satellite in NE they will re-just it for 50$ here is their website _________________________________________________________ |
Gold Member Username: Saqeeb9000Post Number: 4269 Registered: Oct-07 | smart good to see u back but don't put some one info here,, it can cause problem if u know what i mean, u can pm some one if they need it |
Gold Member Username: Way2smartWww.Desifta.com Post Number: 1670 Registered: Oct-06 | thanks...im always here just dont bother replying anymore...... ____________________ is that good?? |
New member Username: PunmcPost Number: 5 Registered: Nov-08 | I want to thank everyone for all there help, turns out i dont have a duel lnb but an lnb that is 119 and behind it is a another one that picks up 118.5. I gather its a two in one thing. I will be going to pick up a new one this weekend thanks once again to everyone |
Gold Member Username: Way2smartWww.Desifta.com Post Number: 1671 Registered: Oct-06 | u have to lock the signal again just to let you know...replacing the lnb will not help.....trust me i tried it already |
