Silver Member Username: Fortec01Post Number: 129 Registered: Sep-06 | are there any bins for fortec i been looking around the website havent found one yet |
Gold Member Username: JustforhahasPost Number: 1254 Registered: Jul-08 | there are hundreds with latest newest Puff 297 fix.. |
Platinum Member Username: NydasPost Number: 13143 Registered: Jun-06 | Ignore justforhaha's. She doesn't know. There are no new BINs for fortec. However for Fortec lifetime Ultra i.e. the specific model known as FLU, you can convert to a Pansat 2700 work-alike and then install the latest PUFF_297 BIN. You can also convert to Pansat 2700 work-alike for b75 BINs, but the support is not very good so I would suggest you stick to PUFF conversion. PUFF_297 for FLU/2500 Conversion to 2700 Full kits for Latest conversion BINs and other files - also for Revert to 2500 Download and unzip into separate directory. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Silver Member Username: Fortec01Post Number: 130 Registered: Sep-06 | r there bins for flu besides the puff |
Platinum Member Username: NydasPost Number: 13158 Registered: Jun-06 | Just above your post - "You can also convert to Pansat 2700 work-alike for b75 BINs, but the support is not very good so I would suggest you stick to PUFF conversion. Remember that all this only applies to Fortec Lifetime Ultra. |
Silver Member Username: Fortec01Post Number: 131 Registered: Sep-06 | am not sure how convert it into b75 bins |
Silver Member Username: MrgregOnt. Canada Post Number: 123 Registered: Dec-07 | canon,I had b75 conversion and converted to puff for the better supported bins.Just use Nalins links to puff and it will run you through the process. |
Platinum Member Username: NydasPost Number: 13160 Registered: Jun-06 | Canon labtec: THE FULL INSTRUCTIONS ARE THERE IN THE FULL KITS. I still recommend you go the PUFF route. PUFF_297 and b75_297 for FLU/2500 Conversion to 2700 Full kits for Latest conversion BINs and other files - also for Revert to 2500 Download and unzip into separate directory. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Platinum Member Username: NydasPost Number: 13161 Registered: Jun-06 | The PUFF links are complete, but the b75 links above do not have 297. However, you can use the full kits and then use the b75_297 by "Black Tyger" from |
New member Username: NazarnaseerEast windsor, Nj Usa Post Number: 10 Registered: Nov-08 | How can I get CBN on BEV. |
Silver Member Username: Fortec01Post Number: 133 Registered: Sep-06 | are there new bins for flu |
Silver Member Username: MrgregOnt. Canada Post Number: 133 Registered: Dec-07 | [link removed] canon The latestB75@PUFF files are at this link. |
Bronze Member Username: The_choosen_oneMAY FTA LIVE FOREVER Post Number: 52 Registered: Jul-08 | whats up greg. canon here you will find both puff &b75 bins enjoy. Black Tyger PUFF Bin v297.zip File Type: zip Black Tyger B75 Bin v297.zip |
Silver Member Username: MrgregOnt. Canada Post Number: 134 Registered: Dec-07 | Hey Choosen how are you. They are both at my link as well.This forum must not like Crazy ah. |
Bronze Member Username: The_choosen_oneMAY FTA LIVE FOREVER Post Number: 54 Registered: Jul-08 | good greg i saw you at crazy the other day.hows everything with you |
Silver Member Username: MrgregOnt. Canada Post Number: 135 Registered: Dec-07 | Im doing pretty good but these sites get a little boring until blackouts hit. |
