Plymouth,I forget to asked you about my existing LNB.first LNB is digiwave dual lnb the second one is DSS dual lnb eagle pro.Are these LNB are sircular or linear,If they are linear still i can use it?If its so can you give me the right antena set up pls For LInear & Circular Echo 8/10(110w) Eho 7 (119w) LNB TYPe ? LNB type ? LNB freq ? TP Freq ?
Thank you again for your continous support for those who need help like me
Here is a list of satellites and the correct lnb's to use with them:
61.5W Echo 3 - use standard circular lnb - 11250 MHz 63W Estrela - use linear lnb, either universal or standard linear- 10750 MHz 71.8W Nahuel 1- linear lnb, either universal or standard linear- 10750 MHz 77W Echo 4 - circular standard lnb - 11250 MHz 79W Amc 5 - linear lnb, either universal or standard - 10750 MHz 82W Nimiq 2 - circular standard lnb= 11250 MHz 87W Amc 3 - --- linear lnb, either universal or standard - 10750 MHz 91W Galaxy 11- linear lnb, either universal or standard- 10750 MHz 91W Nimiq1&3- circular lnb standard= 11250 MHz 93W Intelsat 6- linear lnb, either universal or standard-10750 MHz 95W Galaxy 3c- linear lnb, either universal or standard - 10750 MHz 97W Intelsat5- linear lnb, either universal or standard - 10750 MHz 101W Amc 4 - linear lnb, either universal or standard- 10750 MHz 103W Amc 1- linear lnb, either universal or standard- 10750 MHz 105W Amc 15- linear lnb, either universal or standard- 10750 MHz 107.3W Anik - linear lnb, either universal or standard- 10750 MHz 110W Echo 8 & 10,X - circular lnb standard - 11250 MHz 111W Anik f2 - linear lnb, either universal or standard - 10750 MHz 116.8W Satmex5 - linear lnb, either universal or standard - 10750 MHz 119W Echo 7 - circular lnb standard - 11250 MHz 121W Echo 9 - linear lnb, either universal or standard - 10750 MHz 123W Galaxy 10r - linear lnb, either universal or standard - 10750 MHz 127W Galaxy 13 - linear lnb, either universal or standard - 10750 MHz 129W Echo 5 - circular lnb standard - 11250 MHz 148W Echo1 & 2 - circular lnb standard - 11250 MHz
Plymouth yes i forget to tell you where i live.I live somewhere in BRAMPTON on.canada are those linear or circular. before i used those LNB for my bev.ok thanks again
yes Plymouth dual outputs one LNB you can use two receiver.Again thanks guys for all your support.
here`s my dish set up data from the website of dishpointer:i`m from brampton bev; Sat 82W&91W El---39.6deg & 38.3deg Azmag--193.6 & 206.4 For combine 82W & 91W El 38.95deg. Azmag 200.00deg.
For DN 110W 119W EL 26.2deg & 31.2deg AZ Mag 240.1deg & 230.5deg
for combine 110W & 119W El 28.8deg. Azmag 235.4deg.
Plymouth,I try those TP FREq. that you give me still no luck.I`ve signal 85 but the quality 0-90 but not steady its only flashing,and i dont see any sat. flashing in my screen supposed to be match in my antena set up the sat. i choose right?If i try to swing a little bit my dish the quality is gone,Here`s my dish data from dishpointer website:
Existing set up i marked this
Bev: for 82w & 91w El 39.6deg. & 38.3deg. Azm mag 193.6 & 206.4
DN: for 110w & 119w El 26.2deg & 31.2deg Azm mag 240.1deg & 230.5deg
So if i`m going to hit the 110w you just subtract the El.39.6-26.2 right? its 13.4deg el. for 110w so you have to down your dish at 13.4deg from the original reading.For Azimuth same procedure you just subtract AZ 240.1-193.6=46.5 so facing at the back of your dish turn to the right at 46.5deg right?Did i missed something Plymouth pls.help thanks
And Plymouth which one of this two sattelite should i hit first easily i`ll just depending on you coz its my first time bye for now and more power
"""So if i`m going to hit the 110w you just subtract the El.39.6-26.2 right? its 13.4deg el. for 110w so you have to down your dish at 13.4deg from the original reading.For Azimuth same procedure you just subtract AZ 240.1-193.6=46.5 so facing at the back of your dish turn to the right at 46.5deg right?Did i missed something Plymouth pls.help thanks"""
First thing to do is Adjust the skew on back of dish which is 117.2 Second is elevation which must be +-28.75 Third the azimut turn +-28.75 degre to west and must be 224.98.
Turn the dish approx. +-28 degre to west 110 - 82 = 28 degree 119 - 91 = 28 " With it you could be able to aimed your dish. Believe me, it is easier than a motorized dish to set.
Plymouth Regarding about the skew my dish has no skew at the back of the dish you can`t rotate.My dish is only have an angle measurement on the side thrue the pole when you tilt or geting the elevationcwhich means facing to the dish you can push up and down is it not when you getting the elev? thats the procedure of my dish and also you can rotate my dish when you getting the azimuth thrue the pole.I placed the 119w LNB on the left facing at the back of my dish right?and the 110w LNB on the right.And Plymouth iwas confused about the data i dont know how you get the azomuth el.which +-28deg so could you pls get dishpoiter data here is my add:140 hansen rd. north brampton,on.canada for BEV & DN so that i`ll subtract the existing data from bev to dn i trust you thanks
Plymouth,Yes use 2 LNB in on dish 30-33"For BEV since Bev is dead thats why itry to reaime my dish, my bracket its only steel pipe with clamp and screw for the LNBand its for the sat.dish i bought it in the sat. store.Ill put in the arm of the dish horizontally on where i can install my LNB facing to dish.Then the outcome its like a T type,Im for sure you can figure it out.Plymouth i can`t edit anymore my add. coz its more than 60min.How can i do it thats another problem im stupid
Yes Plymouth,The picture you show thats my set up for my LNB,If you are facing to the dish 119w is on the right or east side and 110w is on the left or west side,Your picture just put line horizontally on the middle of the LNB thats my pipe to hold the LNB or I screw there so its formed like a T and I dont have skew in my dish.This is existing dish for my old sat. before, and it work to Bev I dont know what kind of brand is this the manual I loose already sorry about that.
