Need help for setting up viewsat ultra
Username: Sodhibss
Toro, ON.
hi guys. as i dont have any technical knowlege what i know i m providing u here reciver--> viewsat ultra vs2000.
reciver info
bootloader 0.12
main s/w pftausw-080929u
satellite uoo6
h/w v0.1
there r two dish setup i dot know the exact setting but one is facing west and one is facing south.
few days ago it was running awesome but after i scan satellite it only shows eco's channel and non of them r working.
i tried to upload my reciver with these file
SATINFO_07.sat
U009_plat-xtreme.sat
VIEWSAT_ULTRA_V0143.PGM
as i was tring to fix it by reading thru previous thread. but non of works.
now my reciver dont even show auto-roll insted it keep on searching signals.
pls give me step by step info how i can put it back to working . earlier when its workin i was abe to watch indian as well as english channel .if u futher need any else info post me.
thanks in advance
regards
Username: Plymouth
Post Number: 5169
baljeet sodhi
Load this file now.
Unzip it and put it on your USB key
[link removed]
Load this file in your receiver.
Username: 3dges
Compton
Post Number: 76
is this file working right now ???
Username: Mohamad_obama
Terhan, Iran Iran
Post Number: 127
yes
Username: 3dges
Compton
Post Number: 77
alright i just tried this one and it works
Thanks
Username: Plymouth
Post Number: 5177
You are Welcome
Username: Sodhibss
Toro, ON.
plymouth
thanks but still i m unable to set it up with this file.i know viewing is up from back as my sister is able to watch the channel. i think i need to start from scrap coz while setting mine reciver myself i put it back to factory default.
so pls help me setting antena and scanning the sattelite so that i get it back to its working condition.do i need
upload the loader. mine channel dont go to autoroll when the reciver goes down.
sorry for poor english
thanks
Username: Plymouth
Post Number: 5184
baljeet sodhi
Which satellites you want get?
Which LNBs you use?
Username: Sodhibss
Toro, ON.
Post Number: 7
i need indian as well as english channel.
there r two dish one is facing west and other one is facing south both connected with viewsat switch and a single coaxiable cable going to reciver . btw how can i know which lnb i m using do i have to c somewhere in the reciver setting or into dish.
well if u tell me how i will tell u exactly what info is there
Username: Plymouth
Post Number: 5187
Which satellites you get?
Username: Sodhibss
Toro, ON.
Post Number: 8
dish is grey in colour and dish tv written on it and the lnb colour is white.
after doing factory default it automatically feed this info in antena setup
satellite intelsat 705/c 49.9w
lnb power ON; lnb type Universal; lnb high 10600; lnb low 9750;tp feq. 3871
diseqc 1.0 none;motor off; legacy sw none. signal =0 quality = 0
and when i go to auto scan these satellites r there
AMC1 103.0w---AMC8/c 139.0w totallin 11
amazonas 61.0 ; amazons/c 60.9
anik f1/c 107.3w; asiasat2/c 259.5; asiasat 3s/c 254.5; brasil b1/c to b3/c;
echostar 1,2; echostar 3;5;6,8;7;9
galaxy 10r t0 4r/c totaling 8; hispasat 1c,1d; intelsat 5 to 805/c totaling 8
koreasat 2 and 3 ;nss 6; nimiq 1,3; nimiq 2; pas 3r,6b to 9/c totaling 6
sbs 6;satmex 5,5/c; solidaridad 2/c
telstar 10,10/c.
thats it.
i think u ask for it and if not sorry and tell me how i can provide u the correct details.
regards
Username: Plymouth
Post Number: 5196
baljeet sodhi
I don't want the satellite list but the satellite your dish is point.
What language you speak?
Username: Sodhibss
Toro, ON.
Post Number: 9
hi plymout good news i get some of indian channels by reffering to ur earlier post i autoscan scan anik f3 but i m not getting zeetv should i scan ecostar 3 for that . can u tell me which satellite to scan for english channel. just download bin file and unzip with winrar and load it in USB key and load with USB in receiver.
'[link removed] ' latest which u provide me previously
Load this Sateliite info(with USB key):
[link removed]
You dont need key grabber with viewsat
Here is the loader for Ultra( only for dead box):
regard
Username: Sodhibss
Toro, ON.
Post Number: 10
got the rest by scanning eco star3 61.5
Username: Plymouth
Post Number: 5209
Good new my friend
Enjoy
Username: Sodhibss
Toro, ON.
Post Number: 11
some how i configure that my satellite is pointing to echo star 3 61.5
and echo star 9 121.0 i had read and sucesssfuly scan EC*star 3 can u provide me the antena setting for echosatr 9 so that i can scan it too i tried nyself but i end up by doubling echostar 3 channels. thanks
Username: Nydas
Post Number: 12714
Baljeet: Most likely you are pointing to 61.5 (Echo 3) with one sat and to 119 or 110 or both with the other.
On the Echo 3 slate post your settings, particularly the switch settings.
On what you believe to be the 121, post your settings
Also post your settings for 119 and 110.
Usually the switch setting is
119W = Port 1
110W = Port 2
61.5W = Port 3
but this can vary a lot.
