Conv flu face says p.u.f.f. then -75-
Username: Jaye50
Post Number: 138
272 puff bin took.....set up sat.....channels came in prefectly....then recv cut off by itself.....when it came back on it posted puff and then -75- where it just sits no menu or remote recognition.....do i need to reload factory bin....reconvert to puff.....or can i try to reload puff bin as is....??
Username: Jaye50
Post Number: 139
i started from scratch.....i loaded the factory bin.....then ran the puff conversion....then the puff 272 bin....and it's back up....so far.....
Username: Nydas
Post Number: 12670
PUFF_295 for FLU/2500 Conversion to 2700
Full kits for Latest conversion BINs and other files - also for Revert to 2500
PUFF link
Alternative PUFF link
Download and unzip into separate directory.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
