Can this setup work?
Username: Fahadriz8
Post Number: 129
http://img20.imageshack.us/my.php?image=setupjc5.jpg
thats a pic of what it looks like.
Lets say, only one wire is brought down from the 119/110 satellite because of previous setup conditions. can that wire be run through a splitter and plugged into diseqc port 1 and 2 to get 119 and 110. (When its plugged into 1, the 119 channels work and when its plugged into 2, the 110 channels work but its a hassle to change the wires)
Username: Lol
Post Number: 953
lol No but will work with two wires from dish to sw21 then diseq switch
Username: Fahadriz8
Post Number: 130
is there a risk of damaging equipement if its tried?
Username: Fahadriz8
Post Number: 131
and is there a way to get both 110 and 119 with the current setup and only one wire coming down?
Username: Plymouth
Post Number: 5071
Vince
Is the LNB for 110-119 have only one output or you use a switch?
Username: Nydas
Post Number: 12573
Try a splitter designed for bidirectional traffic, preferrably an amplified splitter.
Username: Fahadriz8
Post Number: 132
it has 2 outputs, plymouth but im saying just how its setup right now, because the switch is inside the house.
Username: Nydas
Post Number: 12578
The splitter should be on the output at the LNB.
Username: Fahadriz8
Post Number: 133
Nalin, whats the only way i can make both 110/119 work with only one wire coming down? or what are my options?
Username: Nydas
Post Number: 12579
Conect one wire to diseqC at input port 1 and leave the port 2 empty.
Scan 119 first, using diseqc #1. The disconnect in the antenna setup and scan 110 with diseqc setting as "NONE" (also try 2)
If this does not work, try a splitter before entering DiseqC and the connect the two to 1 and 2.
Username: Fahadriz8
Post Number: 135
Nalin, I tried scanning with the wire in port 1, and i get 119. Then with the wire in port 2, i get 110. you think the splitter will work? and if so which one? since there are so many types.
Username: Justforhahas
Post Number: 707
You do NOT use splitters with FTA!..You use switches!...or nothing at all, depending on your Dish type and its LNB's..
If you have a TWIN or Quad LNB, then you need no switches, ..if you have 2 Dual LNB's, then ya use 1 disque switch that connect FROM the 2 cables from the 2 LNB's..
Username: Fahadriz8
Post Number: 136
Justforhaha, look at the picture i posted in the first post. In this case there is only one wire coming down from the 110/119 satellite. and its a dish 500 with this lnb.
[link removed]
how can i make that work?
this was the setup i was thinking of
Post Number: 713
Thats NOT a picture its a diagram...You need to provide us with real pics and type of disg and LNB's...Nobody can give you a precise answer based on the little info you gave..
Username: Fahadriz8
Post Number: 137
justforhaha, there are two different satellites. one is a twin lnb and a dish 500. the other is a simple for 61.5.
At the moment i have two wires coming into the diseqc switch, one from 61.5 and one from 119.
However in the diseqc when i connect the 119 wire to port 1 i get 119 and when its connected to port 2, i get 110.
I was wondering if instead of running another cable from the 110/119 satellite if i can split the one wire into two and connect to port 1 and port 2 of the diseqc switch.
Any ideas?
Post Number: 714
[link removed]
What don't you understand?...ya run 1 cable to your receiver ( and 2 cables, if ya have 2 receivers) and watch the 110-119 satellites, after your do all the other necessary things, like aim the dish, load software, scan satellites, input antenna settings, etc..
Username: Fahadriz8
Post Number: 138
but i need to have atleast one diseqc switch because i also have 61.5 connected.
Post Number: 715
Vince NO..If using only 1 receiver
If you want the 61.5 also, you can use a single or Dual which has 1 LNB, ....thats Dish 500 pic is a Dish Pro (DP) Twin LNB (has 2 LB's aka 2 round white lens, and 2 outlets)..
Then you must use a simple disque switch, and connect 1 cable from the DP Twin (110-119) into port 1, and 1 cable from the single/Dual (61.5) into port 3...leave port 2 open!...now go into your receiver settings and input that same info, along with all other info like the LNB's types, freq 11250 , etc...then scan the satellites, and watch TV...
Post Number: 716
Your settings will be something like this,even though you have no cable into port 2..
echo 7, 119...port 1 ...lnb type -ocs-dp
echo 8-10,110... port 2....same as above
echo 3, 61.5...port 3...either DP or standard, based on what ya have on that dish.
freq - 11250
etc...
Username: Fahadriz8
Post Number: 139
ok thanks alot so the only way to get 110 is to run another cable down from the twin lnb, the one i have coming down cant be split into port 1 and 2
Username: Fahadriz8
Post Number: 140
is that right justforhaha?
Post Number: 720
NO!...READ..run 1 cable from the TWIN LNB into port 1, and run 1 cable from the 61.5 into port 3 to a disque switch as I stated above..and then input the antenna settings I gave ya into the receiver and scan the satellites!
Username: Nydas
Post Number: 12583
You are too preoccupied with splitting one wire.
The signal on the one wire is good enough for two 119 and 110.
You just do not connect the Disq port 2 - LEAVE IT OPEN. In the software you can call it 2 or "NONE" - either should work.
Username: Fahadriz8
Post Number: 141
k nalin, when i connect it to diseqc #1 i get 119.
what should i do to scan for 110? can u say step by step?
Username: Nydas
Post Number: 12589
As I have said again and again, it is immaterial whether port 2 is connected - 110W will still comethrough as Port 2 with a setting of "NONE"
Make sure you have the LNB type as DSC-DP
Username: Fahadriz8
Post Number: 142
k so change lnb type to dsc-dp.
what do u mean by disconnect in the antenna setup? and when im scanning for 110 where should the wire thats in port 1 should be connected?
Username: Nydas
Post Number: 12593
Wirw in port 1
Set up 119 antenna for scan of port 1 ans scan
set up 119 antenna to none.
go to 110 antenna set up
Set up "None" or 2 - IT DOES NOT MATTER IF YOU DID NOT HAVE WIRE IN PORT 2.
scan.
go to 119 setup and activate Port 1 connection.
After connecting the wire on port q1 physically , YOU DO NOT LOOK AT IT AT ALL.
Just concentrate on installation menu and do as above.
Username: Fahadriz8
Post Number: 143
Nalin on my pansat converted puff i dont see DCS-DP under lnb type? is there another name for it
Username: Fahadriz8
Post Number: 144
I tried what you said but when i turn 110 to "off" in antenna settings it still scans for 119 channels.
When I connect the 119 cable straight into the reviever and set 119 to port 1 and 110 to port 2 it all works fine and i recieve both satelllites.
However I need to use the diseqc switch because i also need to plug in 61.5 into port 3 and when i go back to the diseqc switch i get a "no signal" message for 110.
Note: In antenna settings i have lnb type as standard for the 119/110 satellite.
Username: Nydas
Post Number: 12603
The single wire for an LNB which carries both 119/110 is usually a Dish LNB and you should try LNB type as DSC-DP
Username: Fahadriz8
Post Number: 145
there is no dsc-dp. i am using pansat converted. maybe its under a different name?
Username: Nydas
Post Number: 12610
In pansat converted it is probably listed as "Dishpro"
Username: Fahadriz8
Post Number: 146
k so this is what i did
- Plug the cable into port 1 of diseqc switch
- go to antenna setup, set 119 to port one and scanned.
- then go to antenna setup, set 110 to none and scanned
at this point when i scan 110, it scans the same transponders as 119.
although when i connect the wire directly it works fine. the problem is when i run it through the diseqc switch.
any ideas?
Username: Therepo
Ftaview.com
Post Number: 229
Vince, when you connect a Dishpro twin LNB to an external diseqc switch (in your case a 4x1), you should connect both output ports of the LNB to the switch. You can connect them to ports 1 and 2, then connect your other coax for Echo 3 to port 3. One cable from the switch to receiver.
Each connection from a diseqc switch switch to a DP LNB will only use the default port of the LNB's internal diseqc switching it is connected to. On the twin from left to right, the default ports go 119--110. Thus, you need two cables.
Post Number: 778
Listen to repo..his suggestion will definitely work..run 2 cables from the Twin, and 1 cable from the 61.5
119-port1...110-port2...61.5- port3
This will obvious go against your goal of using less cables from LNB's, but who cares...its no biggie..good luck
Username: Nydas
Post Number: 12628
I think the guy told us that he does not want to get two lines to one reviever.
Username: Mohamad_obama
Terhan, Iran Iran
Post Number: 104
Vince, my man, isn't it perfectly clear as long as you have been here, you should never listen to nalin?
Post Number: 786
Like MicK Jagger said...You can't always get what ya want!
Username: Nydas
Post Number: 12631
Mohamad Obama: The guy is looking for help and this a serious thread. Stay out.
justforhaha's: Keep to the point and the question asked in this thread.
Username: Therepo
Ftaview.com
Post Number: 230
Vince:
Locate your diseqc switch near to the LNBs (including 61.5). Then use the cable that is now running from Twin, connect it to "to receiver" on diseqc -- you have 1 wire to receiver.
Or:
Instead of a diseqc, use an SW21 in your house with existing wires as you have them. Connect the cable from twin to Dish 1 side, and Echo 3 LNB to Dish 2 side (for example). Assign in switches in antenna setup like this:
119 diseqc port 1, sw21 Dish 1
110 diseqc port 2, sw21 Dish 2
61.5 diseqc NONE, sw21 Dish 2
OR:
Similarly, but instead of sw21, use 22khz. Connect line from twin to the OFF side, and Echo 3 LNB to the 22khz ON side (must do it this way). Assign in antenna setup switches as:
119 22khz OFF, diseqc port 1
110 22khz OFF, diseqc port 2
61.5 22khz ON, diseqc NONE
"There are many paths to the top of the mountain, but the view is the same."
Username: Therepo
Ftaview.com
Post Number: 231
Sorry, should read above for the middle option:
110 diseqc port 2, sw21 Dish 1
