never happend this before.. only 82 west is down.. 91 works good.. anyone else having problem my rec nfusion, kbox both down on 82 west only.. pls post with ur rec and if its up on 82 west..
The tp's info has changes on nimi2 (N4) 82, all the tp's FEC frequencies have changed from 5/6 to 7/8, modify your tp's . there is a fix for NF nuv today for fix nimiq82
only for high definition receiver. most of HD receiver has no problem. the regular box has a problem . juan i changed to ratio 7/8 still no quality. we need a sat file updated.
Use a old bin file then scan with it and load latest file and all channels and Tp come back. Nimiq is in geoorbital position since 3 October but is in test until february.
many usa spots beam has changes, I read nimiq 4 will be ON this saturday, that news is from Bev, other things, many usa Tp's are spots beams and has many changes. go to sateellite guy o bell forums , there are many news aboyt spot beams and ch, chanhes
i did what you suggested but still same problem . even with blind scan . the problem there is no coverage . no signalllllllll . u can not get the channels without having a signal
vultra and nfusion. it is reported that nimiq2 has moved to nimiq4 and most of poeple in usa get affected they all lost signal only 2 tp's are working with 11 channles
cartier. that is in ny, other states have the same problems, as kansas ,texas, minnesota,etc, this state is my nextdoor , but arizona and colorado do not have problems .I don't know why? .I am using a xtreme and this is working ok with the 5/6 tp's,. I am almost sure that you are getting only tp's 2 and 3
There are 2 streams Grouped by frequencies and FEC Re-scaning can correct or mess up yor channel line up Depending on what yor receiver locked on
This is going to happen to 91 as well New bin can only allow yo watch TV channels temporarily But won't prevent what's about to happen
I picked October 29th +/- for B#V I don't think they are ECMing or key rolling for the new encoding N*3 on the new stream I don't think yo'll see ECMs next few days until they complete one of many transitions to follow, yo will see package group drop one by one next few days
