Scrambled or Bad channel - every 2 to 5mins
Username: Kambam
Post Number: 12
Scrambled or Bad channel - every 2 to 5mins:
I tried hard reboot and again the same. What is the issue and how to correct it? Help please...
Thanks
Username: Lol
Post Number: 874
would be helpful to know what box you have :-)
Username: Plymouth
Post Number: 4599
First try a hard reboot and you can load factory file then load latest bin file
Username: Lol
Post Number: 877
and if that don't work delete everything Right Plymouth
Username: Kambam
Post Number: 13
I did hard reboot and didn't work. I have pansat 2500-2700(PUFF) and the 288 bin loaded on it.
Thanks
Username: Plymouth
Post Number: 4600
tprs
Nalin can help you
he is the best on pansat and puff
Username: Saqeeb9000
Post Number: 3962
scrambling freezing channel is happening with kbox too..
dn is playing again..
u have to wait for new bin..
Username: Plymouth
Post Number: 4601
Sada
Give 1or 2 channels and satellite who freeze, i want check it.
Username: Kambam
Post Number: 14
Loaded the latest bin 292 and looks like solved the issue.
Thanks a lot.
Username: Plymouth
Post Number: 4604
Good news tprs, it seems that the latest bin files give many problems for many receivers
Post Number: 3965
plymouth some international channels like setmax ,b4u movies, shows freezing sometimes after 2-3 minutes..
82 west is down on kbox..
Username: Plymouth
Post Number: 4610
Sada
Work fine on Vs and Cw
Try a old file then load latest file and reply with the result
