Please Post Working Viewsat Settings for South Asian Channels
Username: Anonymouse
Post Number: 33
Hi Guys,
I've tried a few things and am getting ) South Asian Channels. Tried factory default, old bin, blind scan, etc.
I have a Viewsat Ultra.
Here are my settings:
Satellite: 110
LNB Power: On
LNB Type: OCS-DP
LNB Freq.: 11250
22Khz: Off
TP Freq.: 12224
DiSEqC 1.0: Port 1
Motor: Off
Legacy SW: None
Satellite: 110
LNB Power: On
LNB Type: OCS-DP
LNB Freq.: 11250
22Khz: Off
TP Freq.: 12224
DiSEqC 1.0: Port 2
Motor: Off
Legacy SW: None
Satellite: 61.5
LNB Power: On
LNB Type: OCS-DP
LNB Freq.: 10550
22Khz: Off
TP Freq.: 12297
DiSEqC 1.0: Port 3
Motor: Off
Legacy SW: None
These settings were working fine till Oct. 09 (110 and 119 still working)
Please help. Thanks in advance.
Username: Plymouth
Post Number: 4617
Anony Mouse
Which LNB you use?
On 61.5
LNB Freq is 11250
You use OCS-DP only if you have DP LNBs, if not use standard.
Post Number: 34
Hey Plymouth,
Thanks for the reply. When I put 61.5 on 11250, regardless of whether I put OCS-DP or Standard... it shows 0 quality.
If I put it on 10550 and put either OCS-DP or standard if shows full quality.
I will try again and report back.
Username: Jatt99
How about Viewsat ultra lite? can i do something as viewsat ultra? anybody here expert?
Post Number: 35
Update:
All working now. On the plus side, I was only getting the guide on 611 and 617 before, now I get it on all South Asian Channels.
Thanks Plymouth.
Here's what I did.
1) Factory default.
2) Loaded May 07, 2008 bin.
3) Blind Scan on 61.5 on LNB 11250 w/ OCS-DP
4) Loaded latest bin
5) Auto Scan on 61.5 on LNB 10550 w/ Standard
Username: Plymouth
Post Number: 4626
Anony Mouse
Good news
I dont understand why it work with Tp Freq on 10550, but if it work now.
How many channels you get on 61.5?
I get 102 channels
Username: Plymouth
Post Number: 4627
jatt
Ultra Lite is like Ultra but the remote is different with less function.
Post Number: 36
I got 194, but some are doubles. 102 sounds about right. I'll try to count later tomorrow.
I have no idea why it works like that too, but I'm just happy it works. :-)
Username: Plymouth
Post Number: 4633
Anony Mouse
If you want deleted duplicate channels, go in channel scan and delete the satellite with gargage can, then enter the setting in the satellite setup then autoscan and now all must be ok.
Post Number: 38
I'm also sure that would work, but I don't want to mess anything up now that everything is working. :-)
Thanks for the help.
Username: Plymouth
Post Number: 4645
Anony Mouse
I understand you, duplicate channels is better that no channels.
I' am sure the next files, correct this problem.
