Username: Tgyoung1 Illinois
U.s.a.
Post Number: 120 Registered: Jul-06
Wednesday, October 08, 2008 - 17:33 GMT did factory reset and set satelite for level 81 and quality 99 scan echo7 but no cnn or fox news?
Username: Kirankumar NO Bashing
Post Number: 2983 Registered: Oct-07
Wednesday, October 08, 2008 - 17:40 GMT everything ok here maybe your lnb type is not set correctly
Username: Viruscauser Leesburg,
Georgia
Post Number: 770 Registered: Mar-07
Wednesday, October 08, 2008 - 21:26 GMT Try a TP scan on Echo 7: 12486(H) 20.000 for CNN and 12306(H) 20.000 for Fox News.
U.s.a.
Post Number: 121 Registered: Jul-06
Wednesday, October 08, 2008 - 22:12 GMT ok my tp 12486 doesn't hasve any quality and have no 12306 tp.think my satellite is off some? have several tps missing
Georgia
Post Number: 771 Registered: Mar-07
Wednesday, October 08, 2008 - 22:18 GMT If you know what TP you're missing, you can add it manually. An option you have is to do a Factory Reset which will cause you to lose all your channels and then you can do a Blind Scan on each one of your sats. A blind Scan will pick up any TP that you may be missing. Note down your correct antenna settings before you do a Factory Reset if you intend to do a Blind Scan.
U.s.a.
Post Number: 122 Registered: Jul-06
Wednesday, October 08, 2008 - 23:32 GMT have dish 500 with one wire to each reciever. standard lnb 11250 disqc #1 standard lnb 11250 disqc #2
Username: Plymouth Canada
Post Number: 4546 Registered: Jan-08
Wednesday, October 08, 2008 - 23:53 GMT Terry Do good solution from Abby
Username: Mohamad_obama Terhan,
Iran
Iran
Post Number: 10 Registered: Oct-08
Thursday, October 09, 2008 - 00:07 GMT What kind of answer is that, Stupid? Oh yeah.........I surrender.
