I get all channels with 75-80% strength and quality, but zeetv, B4U and zee cine, strength is 0 and quality is 70% Can any one help why I dont get these channels? Thanks
Nalin, its Captiveworks 600s premium with CW600PV21.07. If you remember I had asked that I want to hook up third receiver and you suggested that I should use a splitter at the LND and split to two switches. I did that. Two former receivers are fine but the problemis with the new CW600s Premium. Most channels are fine on Echo 3 (61.5) TP is 12414/H/2000/3/4 , LNB freq 11250
