nFusion team: release2 (nf_hd_v1.3sR_05a) in this bin is the following updates:
- Glich fix for HD channels (freezing) - Direct channel input in guide - Weather screen added (national only)under system information - user can now stop (auto setup) - PVR recording updates - PVR info on/off (info button toggles) - mass file sorts - file name added (onscreen) (movie name from guide) - continue play function (file groups) - record file name format changed (movie name) - guide schedule (sets file name) - skip to next file (forward button on remote) - JPG (picture viewer) added (you can view your pictues stored) - channel data plus settings(save/restore) under uprade sw - user settings (save/restore) (saves even channel on when saved) - network (ID changed) - instant record (info baner) - instant record schedule (info banner) - record schedule guide - scheduled recording list add - scheduled recording delete - scheduled recording popup in guide - channel view/record (guide) record button sets record - >> forward file << back file (play function) - channel rename (removed) this function will be in standalone app) - channel move removed (this function will be in standalone app)
- channel rename (removed) this function will be in standalone app) - channel move removed (this function will be in standalone app) THESE ARE VERY IMPORTANT FUNCTION TO ME . I MOVE AND RENAME LOT OF CHANNELS.
is there any broadcast that send the signal 1080p???
