Flat Satellite Antenna by "King T.M."
Username: Tapeman
New York City in-HD, NY
Post Number: 3591
SelfSat-H10D
http://self-sat.com
http://self-sat.com/sub02_2.php
Size: W x H x D
47.5 CM x 26 CM x 7.4 CM
19" x 10.4" x 3"
Works on all Ku-band Satellites
Dual Linear Polarization(Vertical & Horizontal)
All types of brackets provided with
Cross polarization improved(adapted by special bracket to adjust skew angle)
Flat & Good design
SB(Signal Block) Film for exact pointing
- Can be Installed Everywhere
- Extremely Small size
- Portable : Bring it Everywhere !
- Easy to Install !
- Ideal for High Definition(HD) reception
- All Accessories included(compass, leveler, etc,..)
Input satellite freq: 10.7 to 12.75 GHZ
Noise 0.7db Typ
Conversion gain 55db
1 Output switchable V/H pol
UploadUpload
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 4235
Yes King i know this flat square dish
This thing(we can't named it dish) come from Europe.
The big problem is; if you went multi-LNBs, it work with motor, but the look with a high angle do not inspire me.
The noise is very high
Username: Tapeman
Post Number: 3592
If someone live in a apartmaent complex
Not allowed to put up a dish
This could be the solution
Username: Plymouth
Post Number: 4240
You are right King
Username: Nydas
Post Number: 11971
Any URL where there has been an independet assessment in North America?
Username: Tapeman
Post Number: 3593
It's relatively new product to N. America
I don't think it's marketed yet
But these are the kind of new stuff I find at the SATCON
This year's SATCON is on Oct 15,16 2008
I will be there both days
Last year Intelsat paid for lunch
