I wasn't asking yo Obviously yo don't know sh*it about Motorola Scientific Atlanta Digital Cable was never hacked I don't know where have yo been sleeping Stick to MPEG
What got my attention is this: Usually what gets my attention is big
Use (IKS) Internet Key sharing anonymously Plug directly into your Neosat or Nfusion Guaranteed to work or your money back
Here is the full article:
CableHack - Online Store > US / FTABINS.NET. Last Updated: August 16th, 2008
Motorola Surfboard SB5100 Premod List Price: $65.00 Shipping: Free Priority Mail (2-3 day delivery) Turnaround Time: 24-48 hrs Guaranteed Includes: SB5100 Modem, Power Cable, Network Cable, Installed Pin Header, CD Firmware: SIGMA X2 Build 142 Availability: Currently In Stock
Qty: -Main Features of the SB5100- No Torrent Crashing Enable / Disable Factory mode Enable / Disable SNMP Filters Locally host your own config TFTP Enforce Hack Download Config File Change SNMP Ports Change Firmware Name AutoBoot - Modem stores config Full Web GUI Built into HTTPD Full Telnet / Shell Access Change Serial / Mac / Config via Web GUI Enable & Disable BPI & BPI+ Use (IKS) Internet Key sharing anonymously Plug directly into your Neosat or Nfusion Guaranteed to work or your money back Easily configured for your Internet service provider via WEB GUI Full Telnet / Shell Access 100% Undetectable over DOCSIS 1.0 / 1.1 / 2.0 Full Support and documentation
-Content Included in CD- Signature Advanced SB5100/SB5101 Tutorial Config grabbers & Editors TFTPD32 (Host your own config files) StormWatch v2.0 SNMP cfgadmin 1.4 /w 1.8 patch Full OID list CMsniff Super SNMP Mac Collector Blackcat (SchwarzeKatze v128) And much more!
-Additional Features- Member Access to forum Remote Assistance available Detailed Video tutorials Product Guaranteed or your money back
Comcast speed test example: here Have questions or concerns? Email us
Please note: These modems will not effect your current cable modem setup in anyway. These modems are designed specifically for Internet key sharing fta receivers, so you can use your IKS feature on your fta receiver safely. These modems can also be used on your pc to reach extremely fast speeds of up to 38mbit down and 10mbit up. There is no limitation on the amount of modems per household.
What's required to get my modem up and running? Some form of basic cable is required. You must also be hooked up to receive a signal from your current cable provider. You will also need to configure your modem accordingly to your ISP. Configuration can be done by following the guides found on our forum at here or by reading the advanced tutorial included with your purchase found on the cd. Modem Configuration is the key component to achieving online activity.
How difficult is it to get started after I purchase one of these modems? 1. You must configure your modem to get online with your current provider. Modem configuration will be done by a graphical user interface built into the modems firmware or by remote applications.
2. If you're using your modem for the IKS feature, you will simply connect your modem directly into your fta receiver via the Ethernet cable provided. Configure your fta receiver to receive an internet connection and begin your safe journey to internet key sharing. But remember, you must configure your modem first before connecting it to your fta receiver.
Its simply that easy. ONE time configuration, and enjoy free and anonymous internet. This is simply the best solution for using internet key sharing safely and anonymously. We also offer live support on the EFNet network in #cablehack.
Motorola Surfboard SB5100 + MEMORY Premod List Price: $110.00 Shipping: Free Priority Mail (4-6 day delivery) Turnaround Time: 48-72 hrs Guaranteed Includes: SB5100 Modem, 16MB Installed memory, Power Cable, Network Cable, Installed Pin Header, CD Firmware: SB5100MoD v 1.0.4 (DD-WRT Advanced GUI) Availability: Currently In Stock
Qty: All Features above + No Torrent Crashing Faster Web Browsing Extreme Versatility Handle over 12,000 simultaneous sockets 16MB Installed memory (Max-Capacity) Enable / Disable Factory mode Change SNMP Port Backup 2MB Dump Interchangeable HTTPD Port Enable / Disable Web Auth Change Firmware Name Host Config inside Modem Backup Non-Vol Enable / Disable Fw Updates Enable / Disable SNMP Filters Locally Host your own Config Full Web GUI DD-WRT Style Full Telnet / Shell Access Change Serial / Mac / Config via Web GUI Enable & Disable BPI & BPI+ And much more!
-Content Included in CD- Signature Advanced SB5100 Tutorial Config grabbers & Editors TFTPD32 (Host your own config files) StormWatch v2.0 SNMP cfgadmin 1.4 /w 1.8 patch Full OID list CMsniff Super SNMP Mac Collector Blackcat (SchwarzeKatze v128) And much more!
So to put it in layman's terms....unlike Disco or Scientific-Atlanta, "Motorola has the added value of being uniquely positioned for the convergence of broadband and wireless by cable operators and telecom service providers
No In Layman's terms Analog cable with analog boxes was hacked Digital cable with Motorola boxes and powerVu encryption was never hacked for nearly 15 years
sorry buddy.... I can search the net too and thats what I found right on the Motorola site that I was on. So try again.
Btw I use a 802.11g Motorola Wireless UBS Adapter WU830G for my satellite internet conection.
oh and I came across this
Every so often, a new set-top manufacturer attempts an entry into cable, flush with the moxie to snitch market share from incumbent suppliers Motorola and Scientific-Atlanta.
They'll break the duopoly, they say. Their invention is usually cheaper, or more muscular, or both.
Pretty soon after that, new suppliers slam into a big, seemingly immovable roadblock. There, they learn that making a digital set-top isn't as easy as stocking up on chips, a chassis, a power supply and a reference design.
The barrier is the jargon jumble known as "conditional access and encryption."
Some people just say "conditional access," tacitly including the encryption part of the process. Others refer to the techniques by brand name - "DigiCipher," in the case of Motorola; "PowerVu" and "PowerKey," in S-A's lingo.
In one big, evident translation, conditional access and encryption is digital-speak for protecting premium services from theft.
More specifically, conditional access mechanisms determine whether customers are authorized to receive a premium service. On the condition that customers pay for service, they get access to it.
In other words, conditional access is the door guard. No pay, no see.
Encryption, not surprisingly, is the top-secret mixing of digitized video bits, to make premium services undecipherable by pirates. It is the secret sauce of conditional access.
In general, here's how conditional access and encryption works in digital cable systems: First, TV shows are digitized, then compressed. To secure the shows (the "payload") for the long, air-and-ground trip to consuming homes, an algorithm - a string of secret numbers - is applied. Algorithms disarrange the digitized video bits in a way that, with any luck, only the headend equipment and associated set-tops know.
This payload padlock happens in two steps. First, a set of security techniques protects the content as it travels by satellite to the headend; there, a piece of equipment called an "integrated receiver/transcoder," or "IRT," decodes it. The IRT then re-encrypts the shows for their ride, over the cable plant, to the digital set-top box.
If the box is authorized (via the conditional access mechanism) to receive the premium content, the encrypted information is de-crypted (unscrambled).
In the old days of analog set-tops, conditional access was generally handled by an addressable controller. Encryption was called "scrambling."
But back to the eager, new set-top manufacturer with the big plans to unseat the incumbents: Usually, their success necessitates a gentle (or not-so-gentle) nudge on the incumbents, from an MSO who wants the new supplier's product. That's because conditional access and encryption systems come in two parts: A headend controller (scrambler), and a secret spot within the digital box that knows the "key" to unscramble the encryption algorithm (unscrambler.)
To go with a new digital set-top manufacturer, then, MSOs need to either replace the headend part - an unlikely cost proposition, if digital TV is already being delivered - or to encourage the incumbents to share their secret sauce.
Despite the barriers, some succeed. Pace, Panasonic and Pioneer, for example, all make set-tops that work with Scientific-Atlanta's equipment; Time Warner Cable had a lot to do with it. Sony is a set-top supplier to cable because Cablevision Systems' technologists insisted on a conditional access and encryption system that wasn't made by the incumbent suppliers.
The last of the MSOs to go to digital, Cablevision didn't have to fuss with replacing expensive headend equipment so as to attract new set-top suppliers. Yet, Sony is a supplier only to Cablevision, because all other MSOs already spent capital on headend equipment to support their digital video installations.
There isn't really a bad guy here. Maligning Motorola and Scientific-Atlanta for protecting their cash cow - set-tops -- is like maligning the cable industry for protecting its cash cow - premium content.
Still, though, it is the existing state of conditional access and encryption that dissuades the big consumer electronics brands from bringing competitively priced set-tops to the industry, and it is conditional access and encryption that makes MSOs grumble about feeling like hostages to the incumbent supplier duo.
The hostage logic is best phrased in an old joke among cable's technical ranks, about the just-as-old issue of when new set-top features will be delivered.
MSO: "When can I have them?" Supplier: "Six months." MSO: "Six months from when?" Supplier: "From every time you ask."
This was funnier, of course, when there weren't video competitors lurking at every corner, luring cable customers with features that cable doesn't have, and that are available now, not in six months.
The ability to be aggressively competitive is vital. So is the need to secure the stuff of aggressive competition. This problem is real. And as with every ridiculously complicated problem, the answer will require creativity and vigilance. This column originally appeared in the Broadband Week section of Multichannel News.
Post Number: 3551 Registered: Oct-06 Posted on Friday, September 26, 2008 - 07:17 pm:
-------------------------------------------------------------------------------- I got this link from FTA bins Is it true? Do yo have any info on this: Cable Ha$ck
Doreen Gold Member Username: Doreenakadj
Ontario Canada
Post Number: 1950 Registered: Dec-06 Posted on Friday, September 26, 2008 - 07:46 pm:
-------------------------------------------------------------------------------- cable has been hacked for years... where have you been?
King Tapeman Gold Member Username: Tapeman
New York City in-HD, NY
Post Number: 3553 Registered: Oct-06 Posted on Friday, September 26, 2008 - 07:52 pm:
-------------------------------------------------------------------------------- I wasn't asking yo Obviously yo don't know sh*it about Motorola Scientific Atlanta Digital Cable was never hacked
(You did not say Digital) you said cable and Doreen gave you the correct answer.
Same old King searching the web to come up with some more
bullshit that has nothing to do with FTA TV to draw attention.
Good job Doreen, keep an eye on this phony.
BTW Nigeria from Africa, didn't you parents teach you any respect? That is no way to talk to a Lady.
It is amazing that K T will post a question and not even look at what s/he C&P. The key parts are: Some form of basic cable is required. You must also be hooked up to receive a signal from your current cable provider. You will also need to configure your modem accordingly to your ISP. Configuration can be done by following the guides found on our forum at here or by reading the advanced tutorial included with your purchase found on the cd. Modem Configuration is the key component to achieving online activity.
Once you configured the modem per your ISP, you are no longer "anonymous". One of the step of confiuge the modem is to let your cable modem know about the modem's MAC address. Without the MAC address, your cable company will not give an IP address to your modem. In the old day, some cable company may not care about MAC address but those days are over.
King Tapeman, wrong again I still have the hack equipment but don't need. I can go to the street open their Cable Box and remove their blank filter.Besides this thread is not about me. King Tapeman vs Doreen a woman. Like I have said before I bet you had your Lardass kicked in school all the time.Man you are in the USA now get a life asswhole.
White Hawk stay out This is an adult discussion I still have turn tables and 45 LP records So what yo got old analog boxes Use yor brains a bit, 13 year old Child
No e-mail Do yo know what I like about yo Yor a real smart person And I mean this in a complement I wish yo were more polite, yo could of accomplished a lot more
I did read it It does say: "Please note: These modems will not effect your current cable modem setup in anyway. These modems are designed specifically for Internet key sharing fta receivers"
It doesn't mean I do trust hackers In fact I don't trust hackers at all Can't always trust theirt claims
I do have more questions than answers This is considered new type of PTA Many things don't add up to me In fact there is no mention about TV All it says cable and infusion It could be only internet speed upgrade hack
Of course yo need basic cable service It's not a satellite It uses cable as a stream If yo only got internet cable, the cable company puts a TV trap filter So yo can only get internet
To me these are the advanced topics that get my attention I was hoping Justforhahas might know something I guess he doesn't Cuz I know he was around this thread
No-email No disrespect I was hoping for someone with experience or first hand info Yor smart I did acknowledge that from yor questions But my main question in first post was about if anyone got info
Use some common sense. Using IKS as an example, FTA box sends a request to an IKS server, and the server sends back data. If it is truly anonymous, how does the IKS server able to send the data back. There are forwarding service you can use but it can be traced. E.g. The guy that hacked Palin's e-mail account.
I never trust hackers Anonymous is what they claim I always say IKS is traceable if IKS server is under the control of authority i.e. get confiscated by investigators Or at least counter anonymous blocker Otherwise they would of shut down IKS infusion by now
But if yo think cable company trace back anonymous IP from local hub Then yo go that wrong They have to know what they're looking for with a 2 way streak It won't trigger or trap anonymous if it's already in the stream (meaning modulated data)
They block ID parity bits It's like trying to find a covered liscence plate number on a certain bridge somewhere with light pitch dark Not unless they search car by car
They can find yo But people with satellite IKS receiver can face same fate An so far no one got caught
I'm not saying I will do it I don't take risky chances even if the odds are little
King...I think you misnderstood what you saw at ftabins..its NOT just about cable TV or hacking it..its about modems and IKS FTA receivers, all modems will not work with IKS..
Welcome to CableHack
Current Inventory We currently only offer the Motorola SB5100 Premod & SB5101 Premod at this time, due to the continuous proven stability and features these particular Model Modems have to offer. However if you have another Model Modem and would like it modified, We will simply modify it for you at the costs given in the store section of this website.
Safe Ordering Please be aware, we only accept payments via paypal & Money Order only at this time. Your order must also have an confirmed shipping address, otherwise our paypal account will block your transaction . If you're not sure what we mean by a "confirmed address" Please see paypal customer service for further support. For Money Order customers, please click here
Shipping We have a strict shipping policy, Which allows us to move modems in a very fast manor. We guarantee your order at your door within 3-4 business days after receiving your order. Upon ordering you will receive an automated email providing your tracking number and date the item has been processed and shipped. All orders are shipped priority mail (2-3 day).
Other We only modify your modem to have the capability to get online, however we cannot clone a MAC address or make the modem "Online Ready" by any means due to laws and regulations against such behavior. These modems will have the capability to enter most major ISP's with the free knowledge provided by the powerful internet.
and this is there own forums.. http://www.cablehack.net/forum/
If this is all about Mac addresses and modems using Ike receivers etc. can I use my USB Motorola adapter and pick up any "cable" or "high speed wireless" Internet connection?
I don't need a router to " barrow/steal" someones Internet. I can if I had an Ike's receiver take someone Else's connection to get the MAC address etc... to download the information that I would need using my laptop and usb wireless adapter. Does that make scents?
