Bronze Member Post Number: 69 Registered: Nov-06 | Hi I have CW600P and hooked with 61.5.Today suddenly the channels SUN Tv&KTV(Tamil Intl channels)are not working.They are saying that those channels are moved and,to contact Dish Network. What happ to those channels and what do I know?Can anyone help please |
Platinum Member Post Number: 11835 Registered: Jun-06 | ON ECHO 3 (61.5W) K TV 12384 (H) and SunTV 12470 (H) |
Bronze Member Post Number: 70 Registered: Nov-06 | Do I need to scan for 61.5 again?Do u know the channel nos they are right now in 61.5 |
Platinum Member Post Number: 11837 Registered: Jun-06 | Just do a TP scan of the above two TPs on 61.5 |
Bronze Member Post Number: 71 Registered: Nov-06 | Can you plz tell me how to do a TP scan on 61.5 for those channels above? |
Platinum Member Post Number: 11842 Registered: Jun-06 | I don't have info on CS600 - Plymouth or Bruce 1 might help. Usually you have to go into the installation part of your menu and you should see the TP scan come up. |
Gold Member Quebec city, Quebec Canada Post Number: 4104 Registered: Jan-08 | Vasu do a auto scan, then when it is ask delete old channels press yes. |
Bronze Member Post Number: 72 Registered: Nov-06 | I deleted the 61.5 channels,but I think screwed up. It also deleted the Antenna Settings for 61.5.I cant find 61.5 in the antenna list anymore.Iam completely lost |
Gold Member Quebec city, Quebec Canada Post Number: 4107 Registered: Jan-08 | Vasu the good settings are: Echo3 61.5W LNB type: standard LNB Freq: 11250 Tp freq: 12224 And do a blindscan with color button on remote |
Bronze Member Post Number: 73 Registered: Nov-06 | thanks, but I have a quality of 60% and signal of 70%,when i did a blind scan,iam not getting ant channels,Anything wrong I did.Sorry Iam completely new to this,thats why |
Platinum Member Post Number: 11847 Registered: Jun-06 | A Blind scan of 61.5 should give you 9 transponders, and just over 110 channels. |
Bronze Member Post Number: 74 Registered: Nov-06 | Also when I tried to create new satellite,Iam putting 61.5 West,it automatically keeps changing to 61.5 East.Can I completely do a factory default and start from the first |
Bronze Member Post Number: 75 Registered: Nov-06 | I even cant find the 61.5 satellite in the Antenna Settings list,so Iam trying to create a new satellite name,thats where the problem is coming |
Gold Member Quebec city, Quebec Canada Post Number: 4110 Registered: Jan-08 | Dont create a new satellite, use the existant satellite. Yes you can try a factory default if you think you have altered some info in installation. I get 103 channels on 61.5 You need to be sure your dish is correctly aligned and if you use a switch, you choose the good port. |
Bronze Member Post Number: 76 Registered: Nov-06 | My satellite is fine,Bcoz I was watching 61.5 channels till this eve,I think I changed somethng.When I do a factory default what do I do next? |
Gold Member Quebec city, Quebec Canada Post Number: 4111 Registered: Jan-08 | Vasu Next you go in menu installation, satellite, put good settings and blind scan. Where are you located for get 61.5W? |
New member Post Number: 1 Registered: Nov-07 | Vasu is right. Sun TV (610) and KTV (667) displays a message "Important service notice: This channel has moved. To schedule your free equipment upgrade please contact out DISH network rep..today at 1-888-....to avoid further service interruption....Thank you for..." But I found these 2 channels on 6160 (SUNTV) and 6161(K TV). Just wondering if these c}hannel numbers are permanent at 61.5 or should we install a new dish for 148 or 118.7 to get these 2 channels. Any thoughts? |
New member Post Number: 2 Registered: Nov-07 | One more thing....I did an auto scan before searching for 6160 and 6161. |
Bronze Member Post Number: 77 Registered: Nov-06 | Ok I will do this,when I do a factory default,do I have to download the latest bin again? |
Bronze Member Post Number: 78 Registered: Nov-06 | Is there any step by step instructions after factory default for CW 600P(like user guide) anywhere,any good website can someone recommend? |
Gold Member Quebec city, Quebec Canada Post Number: 4115 Registered: Jan-08 | Vasu yes load latest bin. Here is the factory bin and Manual http://www.captiveworks.com/downloads.php |
Bronze Member Post Number: 79 Registered: Nov-06 | Ok let me check with my receiver and I am getting problems still,I will let you know. Thanks for the help PLymouth |
Bronze Member Post Number: 80 Registered: Nov-06 | Do I need to load the bin first and then do a factory default or the reverse? |
Silver Member Post Number: 357 Registered: Jul-08 | A factory default resets all the settings back to original factory settings...(all your satellites and antenna settings)...so then U must load up the latest bin and change the settings to correspond to your dish/LNB/switch configuration on the roof, then do a new scan of the satellites that you have LNB's on dish aimed at...then let keys roll in on channel 121 for DN and channel 630 for bev, and recheck the date and time and let the EPG (guide) populate...then reboot receiver OFF/ON using rear switch..but CW receivers have a little different commands like "enable patch" etc, so read the manual linked above.. |
Bronze Member Post Number: 81 Registered: Nov-06 | OK.I want to check if I understoood correct 1.After doing the factory default,I have to load the latest V2.05bin for CW 600S Premium, 2.Then go to the installation and setup the antenna settings 3.Then scan for the channels 4.Do a patch enable 5. Then I should be good to go Is all the steps correct?PLease correct if Iam wrong,I dont want to screw up my receiver again thats why |
Gold Member Quebec city, Quebec Canada Post Number: 4120 Registered: Jan-08 | Yes Vasu you are right. Dont be affraid with your receiver, when i buy my Cw600S premium, i had load 600S bin file and Bruce1 help me for recover this error. |
