GlobeCast: Galaxy 25 at 97.0 (telstar telsat 5) basic set up?
Username: Rsbonos
Hello,
I can't seem to get a signal for Galaxy 25 at 97.0, can someone please provide their set up so I can see what im doing wrong?
I am trying to run it on a CW 700.
The dish I have is big enough.
Thanks.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 3671
RSBonos
Which size dish?
which LNB you use?
Username: Rsbonos
The dish is big enough 33inch or more.
The LNB:
Digiwave, DGL-900D DSS Dual LNB, KU-BAND LNBF, Input Freq. 12.20-12.70, LO Freq. 11.25 GHz
Thanks
Username: Plymouth
Post Number: 3673
RSBonos
DGL-900D is a circular LNB, you need a linear LNB as DGL-880TU for get these 2 sats
You can buy a DGL-1189Q who have Circular and Linear in one with 2 output for each
Username: Plymouth
Post Number: 3674
Here is the link for Digiwave
http://www.digiwavetechnologies.com/index.php?module=pagemaster&PAGE_user_op=vie w_printable&PAGE_id=160&lay_quiet=1
Username: Rsbonos
Thanks for that.
Do you know what type of settings I need to enter, ie. frequency etc.
Thanks.
Username: Mucho
Post Number: 612
RSBonos
A) Transponder .....11716V22,000
B) LNB Freq. ....10750
C) LNB Type ....Normal
D) 22KHz.....Off
E) Diseqc Number if none leave......None
F) Legacy Sw ....OFF
G) Motorised System if none leave....None
