Red shadow on JVC HDTV, need help please!!!!
Username: Jdagher
Ok so I turned on my JVC HDTV on this morning and the screen seemed distorted. It has a red shadow around every object so it is hard to see the screen. It looks like the reflection of the object or image, but it is in red. If anyone knows what the problem is I would appreciate the help. Thank you.
Username: Tapeman
New York City in-HD, NY
Post Number: 3247
Call JVC tech support
Ask if it can be adjusted
Username: Jdagher
kk thanks
Need to Register?
Forgot Password?
Enable HTML code in message
