Trouble with my FTAs
Username: Strider_143007
Swainsboro, GA USA
Post Number: 17
I have a Viewsat Platinum Lite and a Pansat 2700e, both are brand new.
I have a Dish Pro with a Dp34 Switch to it.
First for the Viewsat, I started by loading the factory bin and then doing a factory default. I loaded the lastest Bin and the made sure all the settings are correct.
119 - port1
110 - Port2
61.5 - Port3
Now my problem is this, when I so a scan for all the birds, 90% of my channels work. But for the indian Channels Zee Tv works but Sony, TV Asia and B4U movies don't work it says no signal. But if I change the setting on 61.5 to none on port settings it those channels work but the other channels will have no signal. I don't know what I am doing wrong.
And for my Pansat, when I loaded the B-75 conversion and then the new bin, but when I do a scan on that one, I don't get all the channels. Some are missing.
Could someone please help me on this.
