Frequency
Username: Bvvenegas
Post Number: 274
i try to do a tp scan so i can get sport channel 455 but the frequency # does not even come out to scan how can i find it
Username: Tapeman
New York City in-HD, NY
Post Number: 3174
- What brand is yor receiver?
- What satellite are aimed at?
- Make sure yo got latest bin loaded before any scan
- Stay away from blind scan
- If yo already did blind scan yo may have to do factory default and re-scan
Many times yo may have problems when yo do blind scan on VU-sat receivers
Write down all yor antenna setup before yo do factory default
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 3146
King
We can do a blind scan on many receivers, it's a old problem, with new bin files no problem with it.
Just to delete sat before and Blind scan sat and you dont have duplicated channels
Username: Tapeman
Post Number: 3175
Blind scan in general if yo don't know what channels yo got on a TP
It shouldn't be used for PTA trust me
TP scan or Channel scan is what yo should always use
Designated channels are already preset at each TP upon scan
If for some reason can't access a specific channel then that specific TP should be manually dialed and scanned
Part of the Nagra back engineering is to create bogus Channels with PID that causes other channels conflict
Since they don't use blind scan for paid service
Blind scan is a great feature don't get me wrong
But it could be used against PTA
It has been used against in the past
One time I posted about counter back engineering against VU-Sat
They thought I was to scare PTA users
Until Nite Rider 101 came along
Not too many people always remember what I say
Only Jeff does
If yo wanna believe me that's fine
If yo don't yo can join the others that think I BS
These freq conflict only happen when yo do blind scan
Username: Plymouth
Post Number: 3150
Hey King take it easy my friend I do many time Blind scan on both Provider without any problem on my VS Ultra and you know i have a motor on my dish and Invacom LNB i scan many satellites, it's a old problem, you can believe me.
"If yo don't yo can join the others that think I BS"
King i give you my opinion, dont be worry
Username: Tapeman
Post Number: 3176
Are yo telling me yo do blind scan without getting doubles?
Username: El_birbano
Calle12, Sonora Xxx
Post Number: 87
Now DN ch 455, Tp 12355, echo7
rescan or just rescan this tp
Username: Plymouth
Post Number: 3151
Yes i deleted sat in channel scan and setup sat i want scan and i do a blind scan.
If your tuner inside your receiver is disaligned on Freq. You can have a duplicated because the bin give Tp freq and if its not the same , blind scan can be see as a different Tp freq and give you duplicated channels.
But if you dont do a autoscan and do only a blind scan you dont have duplicated channels.
I hope you understand what i explained
Username: Tapeman
Post Number: 3177
"If your tuner inside your receiver is disaligned on Freq. You can have a duplicated"
I'm gonna choose not to comment on this Plymouth
Yo did the right thing by deleting what yo don't need and that's why yo don't see problems
Let's leave it at that
Also we are hijacking this thread
Username: Plymouth
Post Number: 3153
Yes King we hijack this thread but Young Mac start 2 threads for it
Sorry for Hijacking
Here is the solution Young Mac
https://www.ecoustics.com/electronics/forum/home-video/507453.html
