How Do I Transfer Satellite and Channel Info??
Username: Anonymouse
Post Number: 15
Hey guys,
I have 2 Viewsat Ultras. I wanted to take the Satellite and Channel information from one and transfer it to the other. Is there any way to do that using the USB ??
I know I did it once before, but I completely forgot how.
Any help is much appreciated.
Username: Saqeeb9000
Post Number: 3622
i don't know about viewsat ultra, but i can tell u about kbox.. (should be similar).
if u go to menu and find tranfer data, or usb etc..
and it will say transfer channel data to usb, (this option will come up after u enter ur usb)..
and then save it (u can rename it , whatever u wanna call it)..
and then go to other viewsat ultra and now this time plug in usb and move the right arrow until u see save channel data..
and u can save it that way.. i think it should be similar to viewsat ultra..
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 3069
Anony Mouse and Sada
On Viewsat Ultra we cannot transfert data to USB but on Serial port thats possible.
Anony go to [link removed] and download "General Satellite Info File (compatible with Platinum, Lite, Xtreme, Ultra only !)
Unzip it and load it in receiver.
If you think you miss some channel, just do a blind scan on sats and all TPs coming
Post Number: 3625
oh i thought viewsat ultra had slot for usb...
if they do then why the heck manafactures didn't add this option......
Username: Plymouth
Post Number: 3072
Sada
I dont know why, but support on Viewsat is very good and its very rare we need to do a manual TP search.
But i agree with you that can be considered.
We are only User not Fabricant.
Username: Plymouth
Post Number: 3073
Thanks Tooter but thats not work on USB and you need to unhook one receiver.
Username: Plymouth
Post Number: 3074
Tooter post is disappeared
I think he read the first Anony post.
Username: Dimwitt
Post Number: 828
Flymoth you should disappear-
Username: Plymouth
Post Number: 3079
Big tooth should disappear too
Post Number: 16
Thanks guys for all the help.
Just decided to do everything manually.
I know I transfered the channels and satellites to a USB before. Just don't remember how.
Maybe it was a programming glitch that let me do it, but I remember going to "Receiver Upgrade" and hitting the "F" keys to load channel and satellite data onto my USB. Not working now though. Strange.
