How do I set-up Winegrad 31" dish with the s2100 motor
Username: Viewsat_ultra
Post Number: 47
Hi, I'm currently using my dn equipment with my VS ultra. I would like to use my Winegrad 31" dish with the s2100 motor, But I can't find anyone in Fort Lauderdale FL to aim it. I have the Winegrad 31" dish with the s2100 motor mounted next to my DN, if I adjust the elevation and skew to the same settings as the 500 will that point me in the right direction or are these settings different for this type of dish?
I believe the LNB in Invacom but I'm not sure. After I get this dish pointed properly what are the settings that should be used? (i.e. LNB type Freq...)
Thanks
Post Number: 48
B.T.W. I believe that I have Invacom QPH-031 lnb.
Post Number: 51
Is there any reason to load keys manually ?
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 3091
Rob
you must be a very good tuner for aligned a motorized dish, but i can try to help you.
I have Vs Ultra with 33" motorized dish and a Invacom QPH-031 Universal linear/circular LNB
Username: Plymouth
Post Number: 3093
No need to load keys manually, autoroll do this work for you.
