Platinum Member Username: Nydas
Post Number: 11294 Registered: Jun-06
Posted on Full kits for Latest conversion BINs and other files - also for Revert to 2500 [link removed] [link removed] Please read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Silver Member Username: Jkmago
Post Number: 220 Registered: Nov-07
Posted on Awesome Nalin. Great work. Thanks Cheeers! |
Silver Member Username: Jaye50
Post Number: 121 Registered: Aug-07
Posted on once again....thanx nalin.....you're an asset..... |
Bronze Member Username: Locnoir
Post Number: 73 Registered: Aug-06
Posted on Nadin, is new bin for b75 available yet??? Thanks! |
Silver Member Username: Dimwitt
Post Number: 823 Registered: Aug-06
Posted on Black Tyger B75 Bin v282.zip |
Post Number: 74 Registered: Aug-06
Posted on Tooter, is it for converted pansat 2700? thanks |
Post Number: 824 Registered: Aug-06
Posted on Its a pansat 2700 bin that has been modified to be used in pansat 2500/clones. use at own risk |
Post Number: 75 Registered: Aug-06
Posted on It works!....thanks, Tooter! |
Bronze Member Username: Elvirm
Post Number: 54 Registered: Sep-07
Posted on Nalin, do we have for b75 282 bin, I see only puff? |
Bronze Member Username: El_che
Post Number: 28 Registered: Jan-08
Posted on Hi, is this good for a pansat 2500 clone converted to 2700 ?? |
Post Number: 11295 Registered: Jun-06
Posted on FLU/2500 Conversion to 2700 workalike. Full kits for Latest conversion BINs and other files - also for Revert to 2500 [link removed] [link removed] [link removed] Please read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Silver Member Username: Halo
Toronto,
Ontario
Post Number: 580 Registered: Oct-07
Posted on You can find all new files at www.dishkeys.co.nr! |
