Not getting all indian channels
Username: Rvm
Post Number: 67
English, PPV are fine, however am not getting quality & signal on some of the indian channels. I can scan all the indian/international channels but some channels are still searching signal. why so, any help is appreciated. i have recently change the switch as well.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2910
RVM check if all channel you get are on Horizotal and channel you cant get are on Horizontal.
If yes you have a problem with cable connector
Username: Rvm
Post Number: 68
yes the one on horizontals are the ones searching signal.
there are some with horizontal that I am getting however most of them are on vertical that i am getting.
the cable connector from dish or the one coming to box?
Username: Plymouth
Post Number: 2911
check all cables between LNB and Receiver
That can be btw LNB and switch or btw switch and receiver.
Username: Rvm
Post Number: 69
will chk tomm morn and post..
gdnght
Username: Plymouth
Post Number: 2915
good night
Username: Rvm
Post Number: 70
Checked and I think that problem lies with LNB in the bob... Honestly I don't know how to fix the one in the box.. any ideas/advice.
PS: I checked my other PANSAT box and that works fine with all channels. however it is my viewsat box which has problem.
Username: Plymouth
Post Number: 2945
PANSAT have problem with Capacitor in Power Supply.
Open the box and check the capacitors
Username: Rvm
Post Number: 71
it is the viewsat box which is not gettingchannels. My Pansat is fine, it is getting all channels.
Username: Plymouth
Post Number: 2946
Sorry
try it:
All viewsat box
Go to Code menu
Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00
Delete this 3 provider one by one with F3 on remote
"NEW" do same thing with all provider on Bev provider
09 07 00
09 06 00
09 05 00
09 01 00
08 01 00
no need to delete keys
load last bin for your box
turn autoroll on
Keep on
Bin and autoroll regenerete keys
Resolve problem with lost channel , autoroll, freeze and search signal
"Dont load factory bin"
Thats erase bad data in the box
For box who lost channel and sat setup
ENJOY TV
TESTED and work fine
New issue for problem on Viewsat
Thanks
Reply if it work
Please
Username: Rvm
Post Number: 72
will try and post..thx,
Username: Rvm
Post Number: 73
tried changes, but doesn't work with signal on missing channels. still shows sarching signal on few of the horizontal channels.
Username: Plymouth
Post Number: 2948
RVM do a factory default and rescan all satellites
Username: Rvm
Post Number: 75
thx. it worked after factory default. apprecite your help.
Username: Plymouth
Post Number: 2976
You are Welcome my friend
Username: Nadxia
Dayton, OH USA
Post Number: 22
hey Plymouth, I have the same problem. I got all channels but Indan??? I have pansat2700A. what should I do. Please help.Thanks
Username: Plymouth
Post Number: 2996
Nadeem
Sorry but i dont know Pansat
Start a new thread and ask Nalin
You can try it before:
unhook cable from LNB, do a hard reboot and load last bin and hook cable from LNB.
Power off when you hook and unhook cable
And you can try a factory default and rescan all sats.
Username: Nydas
Post Number: 11268
On Echo 3 (61.5)Some Indian channels have moved, e.g. ZGUJ, APUNJ, GEONW.
Do a Blind Scan.
Or try 12354 (H), SR 20,000 for some of them.
