Nalin help
Username: Dre0834
Post Number: 7
i have a sonicview 4000 and its stuck in boot mode and the i get a 0and then nothing i have tried to load a factory bin but it wont load i still get the same thing and i am using a rs232 cord to load it but it wont load any help would be appreciated thank you
Username: Nydas
Post Number: 11156
In the situation you are in your USB drive will probably not work, but it is worth giving it a try.
You will need to properly load the factory BIN
This URL will point you to factory file and the loader and instructions.
[link removed]
You will need a DB5 null modem cable and a computer having a DB9 serial outlet.
This cable comes usually with the receiver. If your computer does NOT have a serial DB9 output, use a USB to serial converter - but buy it with its own installation CD and make sure you don ot allow your windows XP to install it - instal it from the supplied CD
Instructions for loading using serial cable are here.
application/mswordUpload
Loading SonicView with Null Serial Cable.doc (29.7 k)
