FTA Satellite Receivers FIXES! pansat fixes captive works satopia
Username: Themangod
Post Number: 539
These websites below will be able to support Pansat Captive works Satopia sonicview and all the other good fta receivers. These are all trusted fta satellite receiver fixes forums. new fta receiver bin files setup info and more
[link removed] norw file release site
http://www.dsstester .com no membership downloads
stick to the trusted forums listed above and you will be safe!
Username: Nydas
Post Number: 11079
Kate's spam has started again.
[link removed] - VIEWSATS and ?Sonicview
[link removed] - C00LSATS
[link removed] - CaptiveWorks.
[link removed] - Ariza and Pansat Conversions
[link removed] - Nfusion
Username: Nydas
Post Number: 11080
The following is an example of a very small part of a site
[link removed]
As you can see, it is loaded with information.
DISH FAQ AND HOWTO
118.7, Anik F3, Ecxostar 6...
118.7 Anik-F3, How do I get it?
RG6 Cable length & signal quality
Best dish for 82,91,110,119
Why is my signal bouncing around?
DP34 Switch Help
sick of all the ECM !! options available!!
DishPro and Legacy Info!
How to setup your Dish1000.2 with a FTA Receiver
How to Setup your Dish500 Dpp/Superdish Dp with a HD Receiver
Peaking your dish with a Satellite Finder(TIPS)
Laser Alignment
Laptop no com port question
How to start your motor dish setup, first things first.
How a diseqc switch works
DISHPRO 1000 ~ Official Document & Specs.
Aspen eagle
Broken arm on the dish
A discussion of signal strength and quality...
Nees Help Please!!!Super Dish
The "best" Dishpro Document
FTA Faq and How To's
How To Post Files & Photos
Handy utility for dish effeciency
How to reaim your BEV dish to get DN ( 1 2)
How To Use The Search Features
and many more FAQs.
Username: Thermongod
Post :579
Nalin you are right im just a LOSER spammer.
Username: Themangod
Post Number: 549
be aware of other bad fta forums out there they are bad because they have been named in a law suit at one of there site staff.
for full info on the on-going law suit with totalfta ftadoc purefta and other bad fta forums read [link removed] norw file release site
Username: Nydas
Post Number: 11090
Always go to "home site of your receiver" first. The sites in BOLD offer direct downloads without registration.
[link removed] - C00LSATS and Nfusion
Other reliable sites:
[link removed]
Username: Themangod
Post Number: 557
A. Loading your bin using Null cable:
Connect serial cable (NULL) to PC>Stb
Open up Loader of choice (PVR-Loader 1.1 or Loader2)
Click on Tool>Configuration>Com port (Default is com 1)
Click on Open File
Click on PC>Stb (Notice the progression bar in loader)
Wait for Loader say Completed. Then on box lcd front panel screen say I.N.S.T>END>0000 or until clock count to 0.001
it is verry important. Do not turn the power off to soon
Turn the power off in front and then back switch
Connect all the cables to your box/TV
Turn the power ON from the front and back switch
Press Menu key
Select Installation and press OK
Select Antenna Setup and press OK
Select your Sat.
Here if you have a diseqC switch enter the port #, Motor or Legacy SW
No lnb type need to select (from new, you have only two selection Standard and Universal). Stb will select your lnb automatic
Press Exit and select Yes for saving the settings
Your back to Antenna Setup screen
Here you have Three choices:
1. Channel Scan
2. Auto Scan
3. Blind Scan
Select Auto Scan
Press OK
You are in the Auto Scan window and you see the Bird(Sat.) you selected and on the top of your screen are three options:
1. Search option
2. Network search
3. Scan Start
You don't change nothing, go down and select Scan Start and press OK
You do this for all the Birds (Sat.) you have
Wait for Autoroll and watch TV
Username: Gregraf
Post Number: 928
Anyone who listens to you Kate has there head up there azz.
Username: Themangod
Post Number: 563
hello
yea i give people the court paper and allow them to think and make up there own mind if those sites your naming are safe.
