Missing most of the international channels
Username: Arthur22
I am only getting 1/4 of the internationals channels that I used to get and it said "no signal" I have a Pan*at 2500 with PUFF, since there's no Anik F3 in my sat list I am using 121 to scan internationals and starting today I am not getting most of the Chinese channels, I even tried doing TP scan and most of the ones I am missing still won't come up, can someone help? thanks in advance
Username: Thoronto
Post Number: 51
I was having this problem with my Viewsat, after reseting to factory default, loaded the new file,setting up the dishes again, and scanning one by one. Everything is back to normal.
Username: Arthur22
thanks, will try that
Username: Arthur22
didn't work for me by setting factory default, please help Nalin
Username: Nydas
Post Number: 11137
A.W.: You are having problems because of th edeffective Black Tyger Bin you have installed. Use one of the URLs below and get an alternative BIN.
<b> 'PUFF links' for full kit 276 and files
http://www.savefile.com/projects/808662067
'b75' Links for full kit 276 and files '" also for 'Revert to 2500'
http://www.savefile.com/projects/808662079
