Help! sonicview 360 premier
Username: Raceman24_1999
can anyone help walk me through step by step on how to load latest bin file using my null cable on a sonicview 360 premier
Post Number: 7
can anyone help
Username: Lol
Post Number: 732
why aren't you using the usb stick
Force Loading SV-360 Premier
- turn the the premier off completely
- format flash drive
- copy latest fix to flash drive
- insert flash drive into premier usb port
- press and hold ok button(locate on the front panel) then turn the premier on using the rear power switch, select file and let it load
Username: Tapeman
New York City in-HD, NY
Post Number: 2978
He says null cable Paul
Roy
The basic concept is
- Receiver must be off from back switch
- Download bin and unzip it in yor laptop etc
- Connect 9 pin null cable to both comptr and rcvr
- Yo need a loader PGM
- Open loader PGM and select PC to STB
- Yo now turn on recvr
- It will start flashing EPROM
- Let it do it's thing until completely stop (10 min or so)
Post Number: 9
i know how load 4000 but on this i unzip file but can not get in where i can load on unit..what am i doing wrong
Username: Tapeman
Post Number: 2983
Yo need SV-360's Loader v1.1
Goto FTBINS
http://ftabins.net/forumdisplay.php?f=318
Post Number: 10
i have 1.1 loader i do every step as i do on 4000 but where i go to unzip folder and click on it i see my file and click on it but it does not come down in the box for me to click on to start loading
Username: Tapeman
Post Number: 2985
- Yo unzip it first on yor comptr
right click and unzip all
- Once file is unzipped it will show on loader when yo do file open in 1.1 loader
Other than this I have no clue what yor confused about
Post Number: 11
ok does a 360 premier load same as a 4000?does loader 1.1 look and work same as 201 loader
Username: Tapeman
Post Number: 2987
Loader is loader
As yo open loader PGM file
There is target and distenation
Yo pick the bin(target)
Select the distenation
As yo turn the switch from the back it will start the flashing process
4000 and 360 similar loaders
But they are not the same
Goto FTABINS
Signup and ask yor question there
But I have feeling yor not unzipping file correctly or simply bad file
Username: Themangod
Post Number: 551
yes i think king is right.
use a trusted fta forum for sonicview 360 premier
[link removed] great sonicview home site
[link removed] great site for fta newbies to learn how to setup there sonicview.
http://www.ftabins.com other great trusted forum for sonicview 360
Username: Nydas
Post Number: 11098
Always go to "home site of your receiver" first. The sites in BOLD offer direct downloads without registration.
[link removed] - VIEWSATS
[link removed] - C00LSATS and Nfusion
[link removed] - CaptiveWorks.
[link removed] - Ariza and Pansat Conversions
[link removed] - Nfusion
Other reliable sites:
[link removed]
