"Which Bank?"
Username: Mucho
Post Number: 446
Author Thread: Linear LNB vs Universal LNB
lroy tipit
Username: Lroy
Post Number: 286
Posted on Friday, October 19, 2007 - 05:00 pm:
What the diffenence between a linear LNB and a Universal LNB, and to receive Echo 9 @ 121W, can the Universal LNB be used instead on the Linear
Tapeman
Username: Tapeman
New York City in-HD, NY
Post Number: 1650
Posted on Friday, October 19, 2007 - 10:44 pm:
Linear low power FSS require 30" dish or bigger.
Vertical and Horizontal frequencies (V and H)
Typical Sats like: 93, 97, 101, 118.75, 121
Circular DSS high power DSS require 20" dish or bigger.
Right and Left circular frequencies. (L and R)
Typical Sats like: 61.5, 82, 91, 110, 119, 129, 148
check
www.lyngsat-com
Kavin Reno
Username: Crazy_greek
Post Number: 1255
Posted on Saturday, October 20, 2007 - 10:04 am:
tipit
The answer is NO.
A) The Standard Linear LNB was designed for North America.Local Oscillator 10.750 GHz use.
B)The Universal LNB was designed for lower
Ku band. Local Oscillator 9.750/10.600 GHz
Both are Linear Polarization.
C) 10.750 GHz for Standard Ku band Reception.
(Dish Network) AMC 15, EchoStar 9 & EchoStar 5
11.250 GHz are for Pay TV Reception. Circular Polarization.
LK
Username: Lklives
Post Number: 12972
Posted on Saturday, October 20, 2007 - 10:57 am:
Direct and to the point...good reply Kavin..was watching to see where king was going with his answer..sure don't understand his different "polarity" reply...cause a universal is a linear LNB
lroy tipit
Username: Lroy
Post Number: 287
Posted on Saturday, October 20, 2007 - 02:49 pm:
Thanks Kevin for the explanation, it is clear as mud.....
