HowI get opical sound from CW700
Username: Ennio
Post Number: 43
How I get optical sound (AC3) from CW700? I get only regular stereo!! from my rec.Ihave a stereo receiver with optical IN but non AC3 only stereo!
ONE MOORE PROBLEM
HOW I corect the problem I get duble number chanel but for example on 307 premium chanel on the other 307 fox in spanisch I have several chanel like this I try to rescan the satellite but is the same any help from samebody? THANK very much
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2738
ennio i cant see on CaptiveWorks sites if optical out is there if yes buy a cable to Radio Shack.
For duplicate channels rescan and when it ask for deleted old sat put yes.
Username: Ennio
Post Number: 44
thank PLYMOUNTH
Yes i have the cable and the stereo rec.
but I'm not getting the sound AC3 or 5.1
I rescan and when i delite older scan but no fix THANK anyway !!
Username: Plymouth
Post Number: 2742
OK i found how AC3 Work.
Choose a channel and press red audio button on remote, if this channel offer AC3 you can see it and choose this one and Optical output can work.
Note: If channel dont offer AC3 you Optical dont work and you need to choose audio in stereo.
For channels go in menu
-System setting
-System
to channel No. choose SID
Username: Ennio
Post Number: 45
wORKING !! thank PLYMOUTH
