Help with 2500 converted to 2700
Username: Majikone
Post Number: 20
Hi guys
Help with my 2500 converted to 2700 B&%
What is the bin working for this
I tried the 274 Tivo, No remote
the 272 Tivo when I do a blind scan or try to use channel master it restarts and blocks on 2 7 5.
Any suggestions???
Thanks in advance.
Username: Nydas
Post Number: 10994
The 274 Tivo, is for Pansat 2700A clones manufactured as such.
for 2500 or FLU converted you need conversions BINs.
Because of your mistake you will probbably be better off starting afresh installing Boot b60, BIN 294T and then continuing conversion as per instructions. Note that you will probably need to rescan the sats. Better note down your antenna settings, if you can see them.
Conversion 268, 269, 271,272 and 274 BINs
Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included, including instructions for conversion between the three different boots
Either b75 or PUFF
http://public.box.net/2500_full_kit
and select appropriate section
Read the instructions properly in the section you have chosen.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Most versions after 263 work well with DN. For BEV you will need version 274.
Username: Majikone
Post Number: 21
Thanks Nalin, I'll begin trying now and let you know...
Username: Majikone
Post Number: 22
Hi again Nalin
Trying to reboot with the 3 file didn't work, the b 7 5 continued to roll and the computer gave Write Failed (ER2).
then I tried to load the 269 and voila + the channels from Channel Master.
Everything is working now, I'll try to load the 274 later to see if BV will be working also.
Thanks again for the great help.
