Pansat 2700 No PPV
Username: Cartier1
Post Number: 1899
WHERE R U GENIUS POEPLE WITH PANSAT 2700 CAN NOT FIGURE OUT THIS ,
Username: Nydas
Post Number: 10976
If you have Dishpro setup, the likely cause is horizontal/vertical TPs.
The P0RNS are on vertical TPs.
The PPVs on Echo 8,10 (110W) are on horizontal TPs.
If you get the P0RNS and not the PPV then you have the answer.
Go to lyngsat*com and get frequency for Sat TPs. Then in channel scan menu check each manually but for each horizonal subtract the number of the TP from 25600 and change it to vertical.
Note: Lyngsat lists TPs as L or R as opposed to H and V. L=H and R=V (or vice versa?)
In summary, manually change each horizontal by subtracting its number from 25600 and changing it to vertical. Its called bandstacking.
Username: Ninjad
Post Number: 47
im using bin 269 on pansat 2700. havent put any bins since 5/23. all xxx and ppv working
