Does the FTA work in other part of the world and which sat to choose?
Username: Atok
Post Number: 33
Just curious, If I install the dish and the receiver in India/Pak/Bangladesh or singapore? will I be able to get the same channels? If not is there an alternate to use these FTA's in these countries? Thanks for the info in advance
Username: Similarevil
Post Number: 43
yes there are tons of options available for you...check here...---> http://dsscentral.info/index.php?c=satcalcmap (take the space out)
Username: Mucho
Post Number: 366
ATOK
The same channels NO. You will not be able to get Bell Express Vu or Dish Network in these Countries
Post Number: 54
but there are options.... many good sats there
