Sanyo DS27590
Username: Davidt77
I would like to hook my playstation2 up to this tv, but I do not have the remote and can not get anything to show on channels 3 or 4. I went into the menu mode from the TV and there is no AUX channel option. Anyone good have a solution?...I have dish network hooked up to my TV as well if that helps. Thank you so much in advance
Username: Socialpanic
Ravenswood, West Virginia US
i have the exact same problem but mine is with a 360 [same concept] i lost my remote and to my knowledge there is no way of doing it manually
Need to Register?
Forgot Password?
Enable HTML code in message
