1 LNB for C and KU Band
Username: Jusme
Post Number: 33
I know Invacom makes an LNB for Linear and Circular. And I've read a few people having success getting C band with a 31-36" dish, but my question is this. Is there an LNB that will receive C and KU Band simultaneously on the same motorized setup for true FTA?
Username: Nydas
Post Number: 10629
This is about the closest to you quest but still far from getting all of KU and C band.
Invacom Quad Polar LNB
One LNB to Rule Them All
If you've got a motorized dish this is the ONLY LNB you need!
A· 4 fully switched outputs: Circular, Linear, Circular, Linear
A· Reception of both LINEAR/FTA (10750) and CIRCULAR/DBS (11250) polarization
A· Linear: 30A°, 87A°, 95A°, 97A°, 101A°, 121A°, 123A°W, etc
A· Circular: 61.5A°, 77A°, 82A°, 91A°, 110A°, 119A°, 148A°W, etc
Model: QPH-031 Made by: Invacom
Username: Mucho
Post Number: 243
Jake,
Plymouth and King Tapeman says YES so check with them.
Username: Desisatguru
Post Number: 10
hey I heard that you can't get 77w in usa.is it true? if not then what dish & lnb I need,is dish500 ok to get 77.
Username: Tdti1
Post Number: 43
For c/ku get a dish of 8.5' or larger, a c/ku feedhorn is always best, the qph 031 will only get ku-band.
If you have a big dish a 4dtv is also a good addition for some free DCII and analog channels plus you can sub if you would like.
If you would like to get linear c/ku and circular c-band then get the corotor II plus wideband feed with lnb's.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2339
jake ross
Yes its possible to receive some C band channels but with dish 48"
You can use the same motorized setup for true FTA.
I have this Invacom QPH-031 who work very fine on linear and circular signals
Which C band sat you want?
Teddy do you have link for your C/ku LNB
Username: Tapeman
New York City in-HD, NY
Post Number: 2751
Item BSC621-2 C/Ku LNBF
C Band
Input 3.4~4.2 GHz
Output 950~1750 MHz
LO 5150 MHz
Gain 65 dB
Ku Band
Input 10.7~12.75 GHz
Output 950~1950 MHz Low band
1100~2150 MHz High band
LO 9.75 GHz Low band
10.6 GHz High band
Noise 0.3 dB
Reference http://wsidigital.com/bsc621.htm
Username: Plymouth
Post Number: 2340
thanks King
Username: Tapeman
Post Number: 2752
Jack Ross
I remember yo and I had a good discussion few months ago
There are few ways to get both C/ku with a small dish
But I say at least one meter dish yo can get 65% of many C-band
I'm gonna work on some foot print for C-band hobbyists in few days
Come back and check with me
P.s. avoid White Hawk, Yukon and king_Of_Sats
They are what I named them T.F.R.
I normally avoid their usless questions
Username: Mucho
Post Number: 245
Jack
Teddy, Registered March of 2005 above has given you the correct answer.
Check it out C-Band and Ku-Band Chart.
http://www.cyberestore.com/includes/languages/english/html/dishsize.html
Username: Mucho
Post Number: 246
Jack
Corotor ll Plus used for C-Band & Ku-Band
reception.
http://www.thesatelliteshop.net/chaparral-corotor-ll-plus-combo-pack-feedhorn-with-cku-lnbs-p-122.html
Username: Mucho
Post Number: 247
Teddy
Is it possible to pickup C/Ku Bands with the Corotor ll Plus and a 1.2 meter Dish.
THANKS.
Username: Tdti1
Post Number: 44
Keep in mind the BSC-621-2 has c/ku though the ku-band is universal good for Intelsat-9 ku-band, this unit will not work with 4dtv, for that you would need to use the BSC-621.
If you do want to go with a low cost lnbf I would get the Geosat c/ku lnbf, as many people find it better than the BSC-621 models.
To be 100% honest I would not waste my time with a smaller dish looking for c-band, with a 1.2 you will get the odd very strong transponder with no adjacent birds, other than that you will be wasting your time.
If you do want to just play around for fun get the Geosat for the 1.2 as the real feed will be far to heavy and is recommended for a larger reflector.
If cost is the issue for a big dish look around your hood as many dishes are there for the taking, look for tight mesh with no damage, or a solid steel or aluminium dish, 10' is perfect.
I do have some freinds with 7.5' and 8' dishes yes they work but when you get into it, and try to get feeds with 7/8 fec you will have issues, also with the new dvb-S2 H.264 feeds going up, 10' or 12' is recommended.
Oh and if you get a big dish with the feedhorn you will need a 4dtv or a old anlog reciver to control the servo, most Pansat models do this though to move the dish again the 4d or analog receiver is needed, if you just want dvb feeds on a big dish with feed and lnb's get a Pansat and a v-box or g-box whatever there called... this will give you the ability to move the actuator with the dvb receiver.
Good luck!
