Quad Legacy lnb setup for pansat
Username: Hello2k3
how do i configure a single wire coming from a quad legacy lnb directly into my pansat. At this point any thing i try i keep gettin same channels on both 110 & 119.
Username: Nydas
Post Number: 10606
The following is a C/P from an online retailer.
C/P.
This is the way to go for your expanded 3 or 4 Receiver system. Has built in SW-44 switch and two dual LNBs so it's strickly a bolt on installation. No tedious jumper coaxes to make plus the connectors are all out of the weather making it less likely to need service. There are four outputs which need to go directly 1 to each receiver. This legacy quad will work with older and newer Dish Network receivers but if you don't have models 301, 501, 508, 721, or model 6000 for you system you have to have this Legacy Quad. The Dish Pro Quad is made for the receiver models listed above and is recommended for them. see it in this same category.
Username: Hello2k3
does any1 has answer to my problem? I need to find out how do I configure my pansat as in what settings should i enter for Antenna settings??
Username: Rtap
FL
Post Number: 2182
hello2k3 its normal to get dup;icate channels when scanning.the easiest way is to use channel master to save your channels settings.just go thru the channels and deleate the dupilcates then download channel master(google it)save it and thats it.
as for setting
echo7(119)
lnb type - dish pro
lnb frequecy - 11250
22khz - off
diseq - off
legacy sw - none
skew - leave as is
tp - leave as is
position setting - disable
echo8(110)
lnb type - dish pro
22khz - off
diseq - off
legacy sw - none
skew - leave as is
tp - leave as is
Username: Hello2k3
Post Number: 7
I tried all that and channel starts working but as soon as i change the channel i get No Signal!. I then restart the receiver, the channel starts working but again channel change and No Signal! again
Username: Jurj1
Post Number: 607
"how do i configure a single wire coming from a quad legacy lnb directly into my pansat. At this point any thing i try i keep gettin same channels on both 110 & 119."
"does any1 has answer to my problem? I need to find out how do I configure my pansat as in what settings should i enter for Antenna settings??"
Azzhole, each one of your questions is different. Are u Retarded? post using proper grammar mother fuckerrrrrr
Username: Hello2k3
Post Number: 8
yea its a STD that i got it from ur mom
Username: Jurj1
Post Number: 611
Learn english you stupid Fu*ck
Username: Luser
Post Number: 286
You should have in settings lnb type with legacy lnb1 for 119 and legacy lnb2 for 110 If no quad option available twin setting should work.
Username: Hello2k3
Post Number: 9
I learned how to Fu*ck from ur mom, I think that is enough. She is a good teacher. You should get lessons from her too.
Username: Luser
Post Number: 287
Lnb type NOT Dish Pro LNB unless DP logo on back. In that case it would not be a legacy.
Username: Hello2k3
Post Number: 10
I have a Quad Legacy LNB. For LNB type, I selected Standard. Channel on 119 work when 110 is disabled and channel on 110 work when 119 is disabled. Is there something i have to select in Legacy SW?
Username: Luser
Post Number: 289
If it can't be selected as apposed to standard then yes it would most likely be in sw.
Username: Free_tver
Post Number: 115
i use the setup:
as for setting
echo7(119)
lnb type - standard
22khz - off
diseq - 1
legacy sw - none
skew - leave as is
tp - leave as is
echo8(110)
lnb type - standard
22khz - off
diseq - 2
legacy sw - sw21 dish1
skew - leave as is
tp - leave as is
the settings seem a little strange but i have not had a problemscanning channels or changing channels between the two birds with these settings.
