OFF Topic
Username: Lolol
Post Number: 299
I know this is off topic but it would be great if anyone can answer this and help me out a little.
AVG7.5 is chaning into AVG8.0($55.00 USD) and free version of AVG will no longer be available after May31st. It will still scan the computer but it wont update any definition files. Does anyone know which antivirus can be used instead after May?
Thanks
Regards
Username: Gregraf
Post Number: 515
What a bummer. How will i be able to protect myself from Nalin Nyda's files.
Username: Lolol
Post Number: 301
bump
Username: Master_lee
Post Number: 41
Greg
You are not as dumb as some here think you are. Who are you working for?
Username: North_of_ontario
Post Number: 859
avast (4.8 free home edition) works great
Username: Doreenakadj
Ontario Canada
Post Number: 1608
here are 2 rapidshare links to get AVG 8.0 etc... with working cracks.... enjoy
AVG Anti Virus Pro 8.0 build 62
http://rapidshare.com/files/113477322/AVG_Professional_V8.0.rar.html
PASSWORD:waz-warez.org
AVG Internet Security Multilanguage 8.93a.1293 + working key
http://rapidshare.com/files/111915712/axvg_8_93a1293.rar
no password
Username: Metallica
Post Number: 670
NOD32 Antivirus crack lifetime
http://www.mininova.org/search/?search=nod32+antivirus
Username: Lolol
Post Number: 303
thanks all...
Is the avast one free edition or free trial for a certain time?
Username: Nydas
Post Number: 10597
For twenty years and usually 2-3 computer at a time, I have never paid a single penny for an anti-virus software.
Go to:
www.zdnet.com
www.download.com
and get a free antivirus program.
Username: Nydas
Post Number: 10598
http://www.freebyte.com/antivirus/
http://antivirus.about.com/od/antivirussoftwarereviews/a/freeav.htm
The answers may surprise you. This review looks at three free antivirus solutions: AntiVir PersonalEdition Classic, AVAST 4 Home Edition, and AVG Free Edition.
http://www.free-av.com/
http://www.thefreesite.com/Free_Software/Anti_virus_freeware/
Username: Themangod
Post Number: 305
thanks for the info
user for users
Username: Guanajuatos_best
Post Number: 217
need help on downloading a video converter
Username: Dude123
Post Number: 2332
Try here:
https://www.ecoustics.com/electronics/forum/off-topic/289508.html
this is the OFF topic section and I am sure someone will be able to help you out there.
Username: Jppatelahd
Post Number: 90
To Dorren : the license of AVG 8 pro has expired... what to do? how to install that?
Ontario Canada
Post Number: 1611
Jignesh ... try this one
since you have already installed the program go to the registery area in the AVG Pro 8 and replace the code with....
75VNU-TH1RR1-L7-P03-C01-S3S9MD-2YN-3AUS
ACTIVATE Legally for 1 year subscription with this code. I hope this helps
Ontario Canada
Post Number: 1612
THE ONLY PAISA LEFT... what kind of video converter you looking for . DVD , AVI , MPEG. Xvid...etc... ?
Post Number: 96
thanks for reply Doreen...
when i install AVG pro 8 it says u have already installed avg 7 so it means i have uninstalled that first and than install this AVG pro 8...
Ontario Canada
Post Number: 1613
yes ... when you see the avg pro 8 show the reg code just replace that one with the one I gave you and continue on ...if it will let you. If that doesn't work let me know and I will find a different build of avg pro 8 for you to try. with crack code inclued.
Post Number: 99
doreen : i tried two times to install but its failes.. the code is working but installation cann't finished successfully.. now can u tell me what to do???
Username: Dude123
Post Number: 2334
AVG 8.0 free version is available aswell get it here:
http://www.download.com/AVG-Anti-Virus-Free-Edition/3000-2239_4-10320142.html?ta g=lst-1&cdlPid=10834624
Username: Dude123
Post Number: 2335
Works awesome thats the one I have and I like it...
