NON PUFF B75?
Username: Indopak
Post Number: 101
is there any non puff b75 files out yet,
cuz i cant use the puff ones:-(
Username: Jwl1
Post Number: 292
Indopak--I've posted where to find them about 4 or 5 times now. :-)
Username: Indopak
Post Number: 103
non puff? i only see puff!!
Username: Jwl1
Post Number: 293
Yes, yes, yes, non puff. Apparently, you aren't looking in the right place.
Ftatalk (.com)
Fta forums on the left
Scroll down until you see pansat 2500 files IN THE FILE SECTION. Click on it. It will take you to the next page with the files on it--both puff and NON PUFF--Aka b75.
However, you MUST be registered to access it.}
Username: Halo
Toronto, Ontario Canada
Post Number: 533
www.dishkeys.co.nr also have non puff files!
Username: Jkmago
Post Number: 192
Lothario_265_PUFF_Pansat/Fortec
http://satnow.info/forums/showthread.php?p=147742
Cheers!
Username: Nydas
Post Number: 10563
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
Either b75 or PUFF
http://public.box.net/2500_full_kit
You must select whether you want to have the old b75 files or PUFF files.
If you have b75 boot, you must convert to PUFF boot to use PUFF BINs
Read the instructions properly in the section you have chosen.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
