PUFF bin is out.
Username: Lucia
Calgary, AB
Post Number: 618
Ukr_Jvvh-Team-PUFF_265.zip
At ftabins.net
I haven't tried if it works yet but i'll do it now,
Username: Lucia
Calgary, AB
Post Number: 619
It works, just let keys autoroll,
and while its autorolling it says -long-live-fta which seemed weird to me but it works fine.
Username: Jaye50
Post Number: 111
thanx much lucia.....appreciate that....
Username: Lucia
Calgary, AB
Post Number: 621
yw.
heres the link for download
http://www.sendspace.com/file/wug6co
Username: Jaye50
Post Number: 112
got it.....again....thanx...
Username: Nydas
Post Number: 10536
Everything for 2500/Flu to 2700 conversion in one package.
Instructions included.
Either b75 or PUFF.
LZMA version not available.
http://public.box.net/2500_full_kit
All downloaded zipped files should be unzipped into a separate directory named appropriately.
You must select whether you want to have the old b75 files or PUFF files
If you have b75 boot, you must use b75 section for b75 BINs or
you must convert to PUFF boot to use PUFF BINs
If you have PUFF boot, you must use PUFF BINs.
If you do not have PUFF BOOT, you MUST first convert to PUFF BOOT using the 640 K 253 version file before installing the latest.
Read the instructions properly in the section you have chosen.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Username: Fuclk
How about the C-2700Tivo files/
Username: Jaye50
Post Number: 114
the "long live fta" thing is a hoot.... :lol:
works fine so far.....
Username: Nydas
Post Number: 10539
For genuine clones of Pansat 2700, the c-2700 clone-safe file is not available yet.
