New CS,Visionsat,Skyview,K-BOX and Nfusion update at crazyfta dot com
Username: Yoman
Post Number: 118
Come and check it out crazyfta dot com released fixes for CS all models except 4,5,6k, VisionSat all models,Skyview all models,K-BOX all models and an nfusin update..very fast..come register and check it out..
Username: Themangod
Post Number: 281
Stay away from none proven sites,
Make sure you download your files from a safe trusted fta forum some are listed in new dish echostar law suites.
[link removed]
[link removed]
http://www.ftabins.net
MAKE SURE YOU DOWNLOAD FROM A SAFE TRUSTED SITE DO NOT GO TO SITES THAT DISH IS INVESTIGATION AND NAMED IN A LAW SUITE
https://www.ecoustics.com/electronics/forum/home-video/474346.html
Username: Lklives
Post Number: 15622
hey Yosanth..please explain, what a K-box is...TY
Username: Nydas
Post Number: 10544
If you are looking for full instructions for conversion of Pansat 2500/Fortec Ultra and files:
http://public.box.net/2500_full_kit
Username: Brucester
Post Number: 1487
LK with a bit of searching this is what i found i hope it helps you
KBOX K1 heros pic's and spec's
enjoy this info from crazyfta
This box does support IKS type serial dongle for key sharing over the internet.
KBOX K1 heros
Main Features
▪ Support Extended 9-day EPG
▪ USB 2.0 Host Support(MP3 Player & JPEG Viewer)
▪ MPEG-II Digital & Fully DVB Compliant
▪ Blind Scan
▪ Multi-LNB Controlled by DiSEqC Control Version 1.0, 1.2 and USALS
▪ Multi-Satellite Search
▪ On-Screen Display with 65535 Color Full Resolution
▪ Favorite Channel Groups
▪ Powerful Channel Control by Favorites, Lock, Skip, Move and Delete
▪ Channel Sorting by Alphabet, Transponder and CAS
▪ Multi-language Supported (OSD & Menu)
▪ Closed Caption Support
▪ Maximum 10,000 channels Programmable
▪ Multi-picture Display
▪ Parental Lock / Receiver Lock
▪ CVBS Video & Audio Output via RCA
▪ Component Y/Pb/Pr Output via RCA
▪ S-VHS Video Output
▪ Optical & Coaxial Output for Digital Audio
▪ Software & Channel Data Upgrade via RS-232 & USB
▪ Universal Remote Control
Specifications
Tuner & Channel Decoder Input Connector
F-type, IEC 169-24, Female Loop through out
F-type, IEC 169-24, Female Frequency Range
950MHz ~ 2150MHz Input Impedance
75U, unbalanced Signal Level
-65 to -25dBm LNB Power
13/18VDC, max.400mA 22KHz Tone
(22¾2)KHz, (0.6¾0.2)V DISEqC Control
V1.0/1.2/USALS Compatible Demodulation
QPSK Input Symbol Rate
2 ~ 45 Ms/s FEC Decoder
1/2, 2/3, 3/4, 5/6 and 7/8 with Constraint Length K=7
MPEG Transport Stream A/V Decoding Transport Stream
MPEG-II ISO/IEC 13818 Profile Level
MPEG-II MP@ML Input Rate
Max. 15Mbit/s Video Formats
4:3 LetterBox, 4:3 PanScan, 16:9 Video Resolution
720 x 576, 720 x 480 Audio Decoding
MPEG/MusiCam Layer ¥°&¥± Audio Mode
Streo/Joint stereo/Mono Sampling Rate
32KHz, 44.1KHz and 48KHz
Main System Main Processor
Conexant Virgo(32-bit RISC CPU 180 MIPS) Memory
Flash-ROM : 2 MBytes
SDRAM : 32 MBytes
Audio / Video & Data IN/OUT Video
CVBS Video Output (RCA)
S-VHS Video Output (Mini-DIN)
Y/Pb/Pr Video Output (RCA) Audio L/R
RCA(Volume and Mute Control)
AC-3 Dolby Digital (RCA & Optical) RS-232C
9 pin D-SUB (Male) type, Transfer rate 115Kbps USB
RF Modulator RF Connector
CH 3 : 61.25MHz
CH 4 : 67.25MHz Output Channel
CH 3 / CH 4 TV Standard
NTSC-M Preset Channel
CH 3 (or TBD)
Software changeable by Menu
Front Panel Slot
1 USB Host Slot Buttons
3 Buttons (CH UP/DOWN, STANDBY) Display
7-Segment (Channel No. or Time) Indicators
2 LEDs (STANDBY, REMOTE)
Power Supply Input Voltage
AC 100 ~ 250V, 50/60Hz Type
SMPS Power Consumption
Max. 25W Standby Power
Max. 8W Protection
Separate Internal Fuse & Lighting protection
Physical Specification Size (W x H x D)
260mm X 55mm X 210mm Weight (Net)
1.2 Kg Operating Temp.
0C ~ +45C Storage Temp.
-10C ~ +70C
